Tall valve covers???
Old Feb 28, 2005 | 10:46 AM
Billdavis83's Avatar
Billdavis83
Default Tall valve covers???
How tall of a valve cover can I run on my 85 before clearance issues? It's a normal deck height 400. Also if I am using it mostly on the street, do I need to install any small baffels for the breathers or PCV valve or anything?
Old Feb 28, 2005 | 11:31 AM
M.Clough's Avatar
M.Clough
I tried to put a tall valve cover on my 85 and it hits the wiper motor.If it is a street car i would run the pcv valve and use a breather in the pass. side
Old Feb 28, 2005 | 12:24 PM
ralph's Avatar
ralph
I used a set of Proform tall covers on my 85. They hit the wiper motor cover slightly but haven't had any issue yet. I'd definitely go with baffles. My 406 pulls a lot of oil from the valve covers and i HAVE baffles. Had to add a separator to stop oil from contaminating the intake charge.
Old Feb 28, 2005 | 03:36 PM
Billdavis83
Separator? What exactly does that mean? I assume it is in addition to the baffle.
Old Feb 28, 2005 | 04:38 PM
LD85's Avatar
LD85
Same here I bought these
Old Feb 28, 2005 | 05:11 PM
ralph's Avatar
ralph
LOL.....a separator in my case is a gutted compressor filter. The oil will drop out of the air stream and accumulate in the filter housing which has a small valve to drain it. Usually have to drain it evey 1000 miles or so.
P.S. Nice covers Larry
Old Feb 28, 2005 | 09:59 PM
eguyett1985's Avatar
eguyett1985
I used a set of these GM Performance valve covers on my 408 and they have the baffles in them..no oil consumption problems with my pcv system. I did have to trim the plastic cover on the wiper motor slightly but everything works.
Old Mar 9, 2005 | 01:05 PM
Billdavis83
How tall are those valve covers ? "?
Old Mar 10, 2005 | 12:50 AM
eguyett1985
They are the short version..the GM performance part number is 12480127. I think they are like 3 to 3.5" tall but I can measure them this weekend if you want. They still require a slight mod to the wiper though...
Old Mar 10, 2005 | 06:43 AM
jerkyboy's Avatar
jerkyboy
eguyette85, do you have roller rockers? Any clearance issues there? Those are exactly what I am looking for. I want to make sure they clear my pro mags. Very nice job btw!
Old Mar 10, 2005 | 09:43 AM
85vet's Avatar
85vet
Cruise-In V Veteran
Hey, Those are my valve covers
Mine are mid height - purchased from Superior Chevrolet and I had Superior powder coat them.
Old Mar 10, 2005 | 10:44 AM
mike 1985's Avatar
mike 1985
LD 85,
do your clear the wiper motor ? Where did you get them from and how do they seal ? Part #?
Mike
Old Mar 10, 2005 | 11:05 AM
jerkyboy's Avatar
jerkyboy
so wait, are there short, Mid, Tall??? I confused
How much for Superior to powdercoat them?
Old Mar 10, 2005 | 12:01 PM
85vet's Avatar
85vet
Cruise-In V Veteran
BillDavis83, sorry about hi jacking your thread, but there are three heights. Short - medium & tall. I will have to see if I can find the part number for my covers. - I had to modify my wiper motor case slightly and use studs w/nuts for the 2 higher bolts - but I have no problem with my 1.6 rockers.
Sorry, I cannot remember how much I paid for the powder coating - I hope to find the invoice for the #'s and then I will know.
Old Mar 10, 2005 | 03:42 PM
LD85's Avatar
LD85
Originally Posted by mike 1985
LD 85,
Mike
Mine clear the Superram and wiper motor easily, and they are teh tall style.
Proform # 12363970 Polished Aluminum Valve Covers
http://www.sallee-chevrolet.com/Prof...ve_covers.html
Old Mar 14, 2005 | 01:14 AM
eguyett1985
Yep, I have roller rockers with polylocks and they clear without a problem. Thanks..
Old Feb 12, 2018 | 12:33 PM
FostersPerformance's Avatar
FostersPerformance
I have a thread on this as well. Have the slant edge covers, tall, and they interfere with the wiper motor. Trying to solve this as well.
Old Feb 17, 2018 | 09:09 AM
FostersPerformance
https://www.corvetteforum.com/forums...per-motor.html
To Tall valve covers???
