Oil pan clearance
Old Feb 28, 2005 | 10:48 AM
Billdavis83's Avatar
Billdavis83
Default Oil pan clearance
Anybody using an aftermarket oil pan on their C4 want to help me out at all? I am wondering what dimension of oilpan will give me sufficient oil capacity and sufficient ground clearance, without breaking the bank.
Old Feb 28, 2005 | 12:50 PM
4bblC4's Avatar
4bblC4
I have a 7pt. summit oil pan with a kicked out sump and a trap door that I'd like to run but i'm afraid it'll hit my longtubes. so here's a bump for ya, cuz I'm wondering too!
4bblC4's Avatar
4bblC4
ahem..... 7Qt.!
Old Feb 28, 2005 | 01:00 PM
LD85's Avatar
LD85
7qt at 7-1/2" deep max, you can go deeper, but it's scary that close to the ground
Old Feb 28, 2005 | 01:01 PM
LD85's Avatar
LD85
www.champpans.com
Old Feb 28, 2005 | 01:13 PM
Billdavis83
www.champpans.com
So at 7-1/2" everything clears? Full suspension travel and everything?
Old Feb 28, 2005 | 03:44 PM
ztrips's Avatar
ztrips
www.champpans.com
What part number Champ pan do you run? Any problems with header clearance?
Thanks.
Old Feb 28, 2005 | 04:00 PM
LD85's Avatar
LD85
Thanks.
I have run the CP 100, nice pan no problems, and then changed to the CP 50, nice pan a little deeper.
Old Feb 28, 2005 | 05:04 PM
pipe's Avatar
pipe
I just bought the TPIS 7qt. pan. It has a trap door and a windage tray plus a magnetic drain plug. It was $185 not too bad. Gold irridite finish to match my timing chain cover. Won't know if it will clear my Headers till the new motor gets put in. Thats a hell of a time to find out huh?
To Oil pan clearance
