Eureka - I found sumthin
Old Mar 2, 2005 | 02:55 AM
subman's Avatar
subman
Default Eureka - I found sumthin
Problem #1 - On my 91, have had some challenges with the ABS (see post http://forums.corvetteforum.com/show....php?t=1022800 ), so I bought a scan tool to read the ABS codes. Flashed 1-2, 1-2, 1-2 then 7-5. Cool, now I can go somewhere. Wrong. "Lateral Accelerometer circuit This code will set when there is a short or open circuit problem in the associated circuit"
So what is / where is this lateral accelerometer circuit,
how do I check it,
how do I trace down a short or open circuit?
Problem #2 - Would not idle, seemed to be set way to low. (see post http://forums.corvetteforum.com/show....php?t=1025488 ) I took apart the throttle body, cleaned it - I don't think it had ever been done in 123500 miles - replaced the IAC and it started on the first click. Cool. But now the idle won't go below 675. The TPS at it's lowest setting is at .315vdc and highest is .585vdc. Before the lowest was .515vdc and highest was .655vdc. There is no slots on the TPS, but I can get a little adjustent. Did not bother with the WOT numbers yet. The IAC has the dual taper type pintle and was set at exactly 1 1/8" from base. Cannot find any vacuum leaks nor anything keeping the throttle open. Any ideas on how I may have screwed up? Something else to check out?
Any help on either of the problems is greatly appreciated.
Subman
Old Mar 2, 2005 | 03:21 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Is this and LT1 or an L98.
I think what your asking it under the radio center of console.
Old Mar 2, 2005 | 03:38 AM
VetteNoob's Avatar
VetteNoob
Crap! Didnt get the manual out to you. Im taking a pic of the LAC section for you....post pic in a few.....
Getting you pics of LAC info and Code 75 diag procedure.
Here you go.
Code 75 Diag Procedure
LAC Info
PM or email me if you want any additional info.
Dumb question on your IAC setting...did you plug it back in after setting it?
Old Mar 2, 2005 | 08:39 AM
JAKE's Avatar
JAKE
On the 86 I was told it's bolted to the floor board under the dash temp control unit. Don't know about your year though.
Jake
To Eureka - I found sumthin
