Keyed LT1 Damper/Harmonic Balancer
Old Mar 2, 2005 | 09:57 AM
Herb's Avatar
Herb
Default Keyed LT1 Damper/Harmonic Balancer
I'd like your opinion on what keyed damper to get for my 93 Procharged
Vette. Also who has the best price.
I just wish I would have known the stock one wasn't keyed because I would have changed it during the blower installation.
Also, is the Fluid damper brand all it's cracked up to be?
Herb
Old Mar 2, 2005 | 10:39 AM
Baldturbofreak's Avatar
Baldturbofreak
I run the Ati damper it is a VERY high quality piece, abeit for $389 it ought to be. It's in the summit catalog.
Old Mar 2, 2005 | 10:56 AM
LPDesRoche's Avatar
LPDesRoche
Just take your hub off and bring it to a machine shop and have them key it. Alot cheaper and just as good. That's what most LT1 supercharged guys end up doing.
Lee
Old Mar 2, 2005 | 01:23 PM
ztrips's Avatar
ztrips
It's not as easy as just replacing the hub with a keyed one... The factory LT1 cranks have a "notched" key, so there is nothing sticking out of the crank where the keyway on the hub is. You need to pull the crank timing gear, remove the notched key, insert full key, put timing cover etc back on, and THEN put the keyed hub on...
BTW- Greg at blowerworks is getting a bunch of ATI 8 rib/6 rib blower crank pulleys in. Not sure how that would work with your blower but they work with vortech's...
Old Mar 2, 2005 | 02:54 PM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I have a cola crank in mine,built the motor.
Old Mar 2, 2005 | 07:10 PM
BAM92's Avatar
BAM92
I think Moore Perfomance sells them new for 150.
To Keyed LT1 Damper/Harmonic Balancer
