Winaldl advice
Old Mar 2, 2005 | 11:03 PM
mikenfl's Avatar
mikenfl
Default Winaldl advice
I recently built an aldl to pc interface cable and downloaded winaldl onto the laptop. Is there a site that anyone could direct me to that would help in interpreting the data and explain what readings a good running car should display? Mine is an '85 4+3 coupe. It is not setting any codes and runs great except for seeming a little rich at cold start. So why don't I just drive it and leave well enough alone? I'd just like a little more insight into what's going on so I can keep it running strong.
Thanks.
Old Mar 3, 2005 | 08:59 PM
-js-'s Avatar
-js-
You could try the manual for Datamaster http://www.ttspowersystems.com/softw...cs/dm32man.pdf
Old Mar 3, 2005 | 10:42 PM
MrNuke's Avatar
MrNuke
Does your '85 raise the rpm to 1000 and go into diagnostic mode when you use winaldl (I presume you too need the pin to put the aldl connector into data sending mode.)
Winaldl should be able to show all the data on the other pages with all the info you need. Only problem is the damned diagnostic mode.
To Winaldl advice
