Help... Damaged Fiberglass
Old Mar 3, 2005 | 02:14 AM
JerryDaugherty's Avatar
JerryDaugherty
Default Help... Damaged Fiberglass
Someone got me in a parking lot and damaged the fiberglass right over the front wheel. So its the hood. Its chipped on the corner but not missing its like shattered.... Its about 3 by 3 inches big. I was wondering how hard this would be to get repaired... or how much $$$ it would be is more like it. Im trying to sell it so I would like to get it done ASAP. Thanks
Old Mar 3, 2005 | 01:13 PM
88421VETTE's Avatar
88421VETTE
I know how you feel I had the exact same thing happen to my 88.right above the wheel. I was told between $3-400
Old Mar 3, 2005 | 02:26 PM
Rolling Torque's Avatar
Rolling Torque
Cruising
The thing that sucks about that is the fact that the whole hood needs to be painted, meaning, there are no sharp body lines to break the blend and get away with just painting a small area... I would probably charge closer to 5 or 600 depending on the color. And the damaged area underneath also has to be refinished... Pete
Old Mar 3, 2005 | 02:30 PM
Pete K's Avatar
Pete K
A good shop will likely be able to blend the color.They will have to clear the whole hood though. In my area this is a 6-700 dollar job at a higher end shop.
Old Mar 3, 2005 | 02:32 PM
JA94vette's Avatar
JA94vette
When the hood has to be painted, does it have to be stripped of existing paint or is it painted over. Like....fixed section of fiberglass, primed, paint, clear. or do you start over on the whole hood so it is bare fiberglass then prime, paint, clear???
Old Mar 3, 2005 | 03:58 PM
Rolling Torque
Cruising
If the existing paint is in good condition it can be painted over without stripping.
To Help... Damaged Fiberglass
