Valve spring question, When to change?
Old Mar 3, 2005 | 09:03 AM
Matt383's Avatar
Matt383
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
Default Valve spring question, When to change?
Without looking at my log book, I am guessing I have about 200 runs on my motor.
When do you guys change your valve springs?
I would need to do this in the next month or so before I hit the track this spring.
Do you think I could get another season out of it? Or change 'em as a preventitive maintenance thing?
Matt383
Old Mar 3, 2005 | 09:48 AM
CFI-EFI's Avatar
CFI-EFI
That depends a lot on your set up. If it's a radical cam and you really wind it up, a change may be in order. If it's more of a DD that you race, you're probably OK. When you start seeing valve float or hydraulic lifter pump up, change them. Although they CAN break, the biggest problem with older, over used, valve springs, is that they lose their tension. For a mild or mid performance engine *I* would wait until they show symptoms.
RACE ON!!!
Old Mar 3, 2005 | 09:52 AM
Matt383's Avatar
Matt383
Thanks.
It is pretty radical.
Not a DD. See sig.
I am thinking change then.
Any other comments?
Matt383
Old Mar 3, 2005 | 09:55 AM
Nathan Plemons's Avatar
Nathan Plemons
Take one off and test it for pressure. If the pressure is still good don't waste the money. If it's starting to get weak, replace them.
It depends on how much overkill was built in when you put it together. I know that the springs I put on my car are way too strong for me to ever worry about them again. They're capable of near .700 lift and I'm only running about .550
Old Mar 3, 2005 | 01:17 PM
ralph's Avatar
ralph
Your best to do what Nathan recommends....test one or two. Or you can buy a tester that clips to the rocker and check them all in the car. As long as they are within the cam specs, you're ok....however, if you're lift is anywhere near the limits of the spring, it might not be a bad idea to change them every couple of years. A broken spring can cause a lot of damage and they aren't that expensive to replace.
Old Mar 3, 2005 | 01:26 PM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by Matt383
Thanks.
Not a DD. See sig.
Any other comments?
Matt383
THAT changes everything. Cam specs and rpm information might have been helpful, but everything else allows one to pretty well imagine. I concur with the others.
RACE ON!!!
To Valve spring question, When to change?
