exhaust???????????
Old Mar 3, 2005 | 02:03 PM
85blkrose's Avatar
85blkrose
Default exhaust???????????
got some extra 3" stainless tubing & 90's left from a project at work i could have if i want it and was wondering what i should do. get hookers and run to an x pipe i make from two siamesed 90's then into two chambered mufflers and then to eliminator tips, or get the tpis and y-pipe and run it through my hiflo cat and my borla 2.5" cat back.i could always sell the catback,what would a 2.5"borla catback w/2500 miles go for if i sold it.
Old Mar 3, 2005 | 06:55 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If you want to run true duals there is enough room (at least under an '87) to run dual 3" pipes with Random Tech bullet cats.
Of course if you already have the cat & cat back, it would be a lot of work unless you are pushing some ponies. Otherwise I would just go with the TPIS headers and Y.
Old Mar 3, 2005 | 07:28 PM
CFI-EFI's Avatar
CFI-EFI
Those 3" pipes are awfully big if you have a 350 and/or a mild engine. Then again so are the 1 3/4" Hookers. 'Nuff said.
RACE ON!!!
Old Mar 4, 2005 | 12:22 AM
cv67's Avatar
cv67
St. Jude Donor '05
Here it comes....
Old Mar 4, 2005 | 10:44 AM
85blkrose's Avatar
85blkrose
Default end goal
RACE ON!!!
my end goal. 383 short block,ram air,52mm tb, proted plenum,em big tubes,tpis bigmouth hogged out for a 1206 felpro,ptl 192/64cc 202-194 heads,zz9 cam,1.6rr, 13/4" long tubes,3"x,ssw chambered muffs and elim. tips, and a ski chip to round it out.i think this will make a really nice motor and should sound really viscious.i will be collecting till fall/winter and completing during the snowy season
Old Mar 4, 2005 | 12:03 PM
CFI-EFI's Avatar
CFI-EFI
My comment still applies, but if that is the plan...Go for it!
What was the point of the original post? To get advice on the value of the cat back?
Also, what is this?
RACE ON!!!
Old Mar 4, 2005 | 01:28 PM
TIMSPEED's Avatar
TIMSPEED
Also, what is this?
I think he's referring to ProTopLine 192cc Intake Runner / 64cc Combustion Chamber / 2.02-1.94 Valve Heads.
Old Mar 4, 2005 | 02:12 PM
CFI-EFI's Avatar
CFI-EFI
I ASSUMED the same thing, but I wanted for him to clarify it. If that's the case, I want the part number of the small block heads that will take that valve combination.
2.02" + 1.94" = 3.96" If there is ZERO clearance between the valves, and the remaining .040" is split evenly, that leaves .020" valve to cylinder wall clearance in a 4.00" bore IF the valves are in the center of the bore, and at 0*. Where are the valve guides? It must take offset shaft mounted rockers. The phase VI Bow Tie heads that have the valve guides offset by .050", only allow 2.10" intakes with 1.65" exhausts.
I take it back. A SBC with those exhaust valves can probably use 1 3/4" headers and 3" exhaust. Especially from 8000 rpms to up wards of 10,000 rpms and above. Even IF it's only a 383.
RACE ON!!!
Old Mar 4, 2005 | 02:53 PM
4bblC4's Avatar
4bblC4
what size dual exhaust should he have with 1.94/150 valves? I have that size (ported vortec heads), manley race flo valves, and around 470hp... I use dual 3" and 1 3/4 headers, I seem to have plenty of low end.
Old Mar 4, 2005 | 03:01 PM
siggy_freud's Avatar
siggy_freud
Dual 2.5's is pretty much all any smallblock is ever going to need.
Old Mar 4, 2005 | 05:44 PM
4bblC4's Avatar
4bblC4
then why does the lt4 have dual 2.75?
Old Mar 4, 2005 | 06:01 PM
4bblC4's Avatar
4bblC4
And the new c6 has dual 3". it is a 500 horse motor. Revs to 7000+
I would think that it wouldn't hurt this guy any if he ran dual 3". would look sick too, being stainless. And the new motor would probably need more than a dual 2.5.... I would think
Just my little thoughts
Old Mar 4, 2005 | 06:03 PM
4bblC4's Avatar
4bblC4
(c6 Z06)
Old Mar 5, 2005 | 02:17 PM
85blkrose's Avatar
85blkrose
sorry for the typo's, my heads are pro topline's 2.02-1.60 64 cc combustion chamber and 192 cc intake runners. i have got 20' of three inch 304 ss non welded tubing from work as well as some 90's and 45's. my plan is for 3" tru duals and it will look
sick as 4bblC4 states especially with dual 3.5" rolled edge tips pokin out from under the rear. might be overkill but im starting the x-pipe monday night at work.dont have a penny in it yet so i wont loose anything by changin my mind later
Old Mar 5, 2005 | 04:46 PM
4bblC4's Avatar
4bblC4
Way to go. I think that setup will work fine. Maybe you will lose some velocity that is needed, but when the new motor is in, it will be perfect. Do it now and forget it. you'll never have to change it again!
Have fun! wish I had some 3" ss tubing!
To exhaust???????????
