ZF 6-Speed
Old Mar 3, 2005 | 06:37 PM
vettmike's Avatar
vettmike
Default ZF 6-Speed
Does anyone know what size allen is required for the drain plug on the ZF 6-Speed?
vettmike
Old Mar 3, 2005 | 06:46 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
good question! I took both my plugs out with a hammer and chisel / vice grips. make sure you use some kind of anti-sieze on those bad boys when you put them back in because they stick, I don't know if it's the magnesium case or what the problem is.
Old Mar 3, 2005 | 06:53 PM
mesteffen's Avatar
mesteffen
17mm
Old Mar 3, 2005 | 06:57 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
Originally Posted by mesteffen
17mm
AutoZone carries a 3pack with 1/2" drive to help get the stubborn plugs out.
Old Mar 3, 2005 | 07:11 PM
bogus's Avatar
bogus
And get a breaker bar...
remove the fill plug first. It is the tightest. Then worry about the drain. Reason? Why empty it only to find you can't refill?
Also, I suggest getting BMW/Castrol TWS 10-60 motor oil as the fill for the ZF6. Great stuff. Many also suggest Red Line and Amsoil.
Old Mar 3, 2005 | 09:50 PM
jrscott's Avatar
jrscott
Just had to order Redline from the local Advanced Auto because it was not an in stock item. Because of the colder weather here in Ohio, I decided to go with the Redline (a little thinner than Castrol) and not the BMW. At this point I'm not sure which is better but I'll find out. Drain plug is 17mm. I would have never thought about taking out the fill plug first; but this forum clued me in on that. Thanks to all...
Old Mar 4, 2005 | 12:27 AM
bogus's Avatar
bogus
describe thinner? 10-60 is pretty thin at cold.
Old Mar 4, 2005 | 01:47 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
TIP: Make sure you can get the 'fill' plug out 1st...don't ask
Old Mar 4, 2005 | 07:25 AM
vettmike's Avatar
vettmike
Thanks guys
vettmike
Old Mar 4, 2005 | 10:40 AM
wake's Avatar
wake
That's the first thing that crossed my mind when I did my trans... I figured with my luck, I'd drain the trans and not be able to fill it...
Old Mar 4, 2005 | 11:20 PM
JCD's Avatar
JCD
All you gotta do is roll the car, how hard can that be? People do it unintentionally all the time!
Old Mar 5, 2005 | 09:06 PM
ClarenceT's Avatar
ClarenceT
vettmike
Mike, I don't mean to be an ***, but please use a descriptive title next time.
Instead of ZF6, try "ZF6 Drain plug - help" or something.
Helps people who search for this later on, along with just plain making more sense
If every thread was labeled "C4 question" we wouldn't have very much fun trying to sort through it all would we?
To ZF 6-Speed
