OK...MY QUESTION IS>>>>>
Old Mar 3, 2005 | 11:31 PM
GS345's Avatar
GS345
St. Jude Donor '11
Default OK...MY QUESTION IS>>>>>
Do I really need to up my TB to a 58 or is the 52 big enough?????
396 LT4, stage II heads/intake, 233/240 cam, 11.1 comp.,headers, 3"cats and exhaust.........:con fused:
Old Mar 4, 2005 | 06:59 AM
GS345's Avatar
GS345
St. Jude Donor '11
Old Mar 4, 2005 | 07:37 AM
RocketSled's Avatar
RocketSled
I dynoed my 383 with the 48 mm and later with the 58 mm TB...it made no difference in power (which just may mean it's not tuned enough to where the TB is the bottleneck, YMMV.)
It _did_ improve off idle performance as less throttle was necessary to allow a certain amount of air to flow.
Old Mar 4, 2005 | 12:39 PM
GS345's Avatar
GS345
St. Jude Donor '11
it is having an idle problem...starts around 500 then finally (sometimes) comes up to where it should be.
Old Mar 4, 2005 | 02:11 PM
RocketSled's Avatar
RocketSled
Do you know how to set the IAC (Idle Air Control) and initial throttle opening? Who did your re-programming for fuel/timing maps?
To OK...MY QUESTION IS>>>>>
