The fan on my 87 runs on high speed for about two minutes then shuts off, it will occasionally come back on but uslually stays off until I let it siy overnight. It will however run at the next lower speed after it quits at high speed. Hardly enough to cool a black interior in Florida.
Motor overheating??
BTW, it will run on lower speeds non stop, never quits.
Its not climate control if thats what you mean, I thought it might be the relay. But the relay probably wouldnt close the high speed at all if it was hosed, or, I guess the coil in the relay could heat and drop contact after a few minutes....
