still have rev problems.....
Old Mar 4, 2005 | 03:51 PM
1990dtgL98squared's Avatar
1990dtgL98squared
Default still have rev problems.....
In my 1990 L98 stick.
At around 4000 to 4500 RPMS, the car buckles and jerks. It looses all power and surges.
Replaced the fuel injectors, fuel filter, fuel strainer, cap, rotor, wires, AFPR. I'm thinking it's either the coil or the fuel pump....any idea which one it could be or if it could be something else?
If you need more info, just let me know, trying to type fast before I go out to dinner.
-Dave
Old Mar 4, 2005 | 03:53 PM
SupaVette's Avatar
SupaVette
I think easiest thing to do would be to put a fuel pressure gage on and see what the car does at those high rpm's. It could be either, fuel starvation at high rpm or the coil breaking down
Old Mar 4, 2005 | 04:29 PM
1990dtgL98squared
Well, I hooked up a gauge and drove around before...the fuel gauge doesn't move.
However, the tach goes crazy when it starts bucking, it literally will go from 0-8000 and jump everywhere inbetween.
-Dave
Old Mar 4, 2005 | 05:00 PM
tpi1986's Avatar
tpi1986
Same problem last year on my 86, changed fuel pump and has been fine since.
Old Mar 4, 2005 | 05:46 PM
6spd's Avatar
6spd
do you have a scanner?? are you getting any knock retard at that rpm??
Old Mar 4, 2005 | 05:55 PM
1990dtgL98squared
No knock counts...
Old Mar 4, 2005 | 06:02 PM
6spd's Avatar
6spd
you said you checked fuel pressure but did pressure drop at that rpm??
Old Mar 4, 2005 | 06:27 PM
6spd's Avatar
6spd
i forgot to ask is your car stock??
Old Mar 4, 2005 | 08:11 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
Well, the tach gets its signal from the ignition system so if it is going crazy, your ignition system might also be going crazy.
If you hook up a fuel pressure gauge and it doesn't falter when the bucking is going on then the fuel pump is ok.
I would replace the coil given the options. They are pretty cheap and easy to replace.
Old Mar 4, 2005 | 09:51 PM
1990dtgL98squared
The car is not stock.
Yes, when I hooked the fuel gauge up, the pressure did not drop nor did the needle go erratic at that RPM. The tach does though. Do coils wear out? And if they do, wouldn't it cause a miss throughout the RPM range?
Old Mar 4, 2005 | 09:56 PM
Pete K's Avatar
Pete K
If the tach is flipping out your problem is probably electrical. I never recommend parts swapping. However, coils do degrade over time and milage. I have had them test good or marginal and actually be bad. Test module, pick up and coil. Inspect cap and rotor. I would bet a dollar to a five that your problem is in your distributor.
To still have rev problems.....
