84-85 Block questions
Old Mar 5, 2005 | 09:48 PM
srsjuju's Avatar
srsjuju
Default 84-85 Block questions
Do any of you guys know if an 84-85 Vette should have a 2 bolt main or a 4 bolt main.
Old Mar 5, 2005 | 09:50 PM
Frizlefrak's Avatar
Frizlefrak
It will be a 2 bolt block
Old Mar 5, 2005 | 09:55 PM
Rich & Lisa_84's Avatar
Rich & Lisa_84
From: I live at www.domesticlugnuts.com I sleep in PA
Old Mar 6, 2005 | 01:14 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
My 85 is 2-bolt.
It's been said that the non-splayed 4-bolt mains are weaker than the 2-bolt.
Old Mar 6, 2005 | 01:27 AM
eguyett1985's Avatar
eguyett1985
Yeah, it is factory 2-bolt main. The 4-bolt main blocks in those years with 2pc rear main seal and passenger side dipsticks came in 1ton trucks only as far as I know.
Old Mar 6, 2005 | 01:22 PM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by CentralCoaster
My 85 is 2-bolt.
That only applies to the 400 CID, 4.125" bore blocks. Chevy never had any splayed 4 bolt production blocks in any size. Except for the 400, 4 bolt blocks are preferable. All L83 and L98, C4 blocks are 2 bolt mains.
RACE ON!!!
Old Mar 6, 2005 | 01:59 PM
CentralCoaster
Thanks for the info CFI. I was aware chebby didn't do any splayed holes, but didn't know what engines the parallel holes applied to.
Makes sense with the larger bore size.
Old Mar 6, 2005 | 02:25 PM
CFI-EFI's Avatar
CFI-EFI
I am only aware of the 4.00" bore, 302, 327, and 350 CID and the 4.125" bore, 400 CID as the only Gen I engines available with 4 bolt mains. All had parallel bolts. The 4 bolt 400 is the weak sister. Otherwise 4 bolt mains are desirable.
RACE ON!!!
To 84-85 Block questions
