changing fluid??
Old Mar 7, 2005 | 09:19 PM
6spd's Avatar
6spd
Default changing fluid??
what's the best way to change the rear end fluid on a dana 44??
Old Mar 7, 2005 | 09:32 PM
rws.1's Avatar
rws.1
from what I've been told the best way is to remove the diff cover...
the easiest is to suck it out with a mighty vac....
But I may have heard wrong... other opinions?
Old Mar 7, 2005 | 11:04 PM
C4396roadster's Avatar
C4396roadster
the mityvac is too small they sell a plunger type dingy cant recall exact name but they should sell it in any parts store it is used to fill and drain fluids through a hose
sorry this is the best description I can give at the present moment
Old Mar 8, 2005 | 03:11 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
This is by far the easiest way. NAPA sells this device....looks like a large grease gun....cheap....works. I bought one just for the diff on my Vette and recommend it.
Larry
code5coupe
Old Mar 8, 2005 | 04:23 PM
bogus's Avatar
bogus
I have a hand pump called a "Mighty-Mite" that does a real good job. About $10.00 at Pepboys.
To changing fluid??
