Engine missing hopefully solved (finally)--surprising finding
Anyway, I was fooling around under the hood the other day to try and check the throttle position sensor. I unplugged the connector to try and get to the contacts to check voltage, etc. and then plugged things back (I threw a DTC 64 since I turned the key on while the sensor was unplugged but this seems irrelevant). The only other thing I did while the hood was opened was my usual check for tightness of wires and connectors that I could reach (e.g., spark plug wires).
This time, I found a wire that I had not previously checked--the lead that goes from the opti to the coil. Of course I could not reach the end that plugs into the opti but I pushed in the end that fits into the coil. To my surprise the wire pushed in a bit and I felt a click. Obviously I seated the wire more fully to its connection in the coil but I did not think much about this.
However, when I drove the car, it feels like new. The miss at idle seems to be gone and the car feels like it's on steroids. It seems amazing that the cause of my problems may have been an improperly seated coil wire but I am keeping my fingers crossed. It's been a few days of driving now since seating the wire and still no engine miss or other problems!
This was back when I changed the wires in the fall.
Who woulda thunk it.
This is a perfect example of what I try to tell guys all the time. Don't over-engineer the problem. Check the basic stuff first; don't just head off to the parts store with your wallet in your hand. Often times it's something really simple.
What bugs me a little is when I make those suggestions, they sometimes get dismissed out of hand, then, 50 posts later, the guy posts he found the cause, which is something I suggested he check in post two.
I wish I'd kept a listing of all the crossed-plug wires, vacuum hoses left off, lifter preload set too tightly, rotors not screwed down tightly, distributors mis-installed, etc.
I, like many others, don't mind trying to help out, but our advice is pretty useless unless it's followed.
There IS a difference between a mechanic and a parts changer.
Just venting.
Jake
Jake
So far still good but one quick question. For engine miss problems, opti seems to be the first item many point to (along with rants about the opti--including the mechanic I visited). Then the list goes on to include crossed-plug wires, bad plugs, bad wires, etc. I am wondering what is meant by crossed-plug wires. I assume this means plug wires close to each other that somehow induce sparking across the wire insulation? Or does this mean wires that physically are attached to the wrong plugs (I would guess the engine would not even run if that were the case).
Thanks also for posting the resolution. It seems so often here I follow threads on particular problems, advice given and troubleshooting procedures only to have the thread die off and never hear the outcome. I can only retain about 10% of what I take in so I need as many happy endings with what solved a problem as I can get.
Cross firing occurs when voltage from one wire jumps to an adjacent wire. Mis-firing occurs when the spark jumps to ground. You can best tell this is happening in a darkened area. When a plug wire has bad insulation you can sometimes see a blue halo around the wire in the dark. Spark may not actually be jumping (yet) but voltage is leaking.
Spark is like water and takes the path of least resistance. If it's easier to jump to ground or to another wire, rather than jump the gap at the spark plug, that's what the spark will do.
Plug wire should be separated by AT LEAST 1/4", preferably more.
Jake
Jake
Cross-firing is what I was thinking of as a Chevy mechanic once blamed my opti problems on cross-firing so they replaced the wires along with the opti. I have all the right looms on the wires but there are still a few locations where I see plug wires that are near or touching other plug wires. It seems this is unavoidable with all the various small passages and obstructions that the wires have to go through as they get near the opti. My guess is that if the wires are in reasonably good shape, they should be resistant to cross-firing even if one wire is touching another--am I wrong?
It's heat that has the primary effect on the plug wires: the insulation breaks down over time from being exposed to the high heat of the engine compartment.
A plug wire should never actually touch another one or anything else (except the wire separators) for that matter. If it touches, say, metal, constant engine virbation can cause the insulation to wear through.
There are lot of after-market wire separators available. There are also several heat resistant insulators available for both the wires and the plug boots. Jesel even has some that are ceramic. I use to always shrink-sleeve the plug wires (MSD stuff) on the race engines.
A little creative routing can keep all the wires where they should be.
Jake
Moroso sells the separators in pairs and some of the auto parts stores, like AutoZone and Pep Boys have them hanging on the rack.
If you're bucks down, you can make them out of plastic cable ties.
Summit and JEGS have websites that list their stuff.
Jake
of course we will need pics of a monster burn out now
Jake
Damn! Sounds just like my dad! And the worst part is that after I had screwed around with a problem long enough, I would finally come to the conclusion that good 'ol dad was right!!! Time to eat some crow... I have been guilty of all of the above
Gotta love it!
