fuel tank gasket ???
Old Mar 10, 2005 | 10:01 AM
Moxxi's Avatar
Moxxi
Default fuel tank gasket ???
I am changing out the rubber gasket that goes between the fuel tank and the filler neck.
Do I need to apply any sort of gasket sealant, or is the rubber itself sufficient, by itself?
Also, I have a code 54. If this gasket is bad, and is allowing fuel pressure to escape, could this be the cause of my code 54?
Old Mar 10, 2005 | 10:11 AM
Unriced's Avatar
Unriced
I am gonna say no to the gasket sealant.
I dont even think they do it at the factory.
Not on my 85 anyway.. What is code 54?
At work...
Old Mar 10, 2005 | 10:17 AM
CFI-EFI's Avatar
CFI-EFI
I have never changed that gasket in the several times I've changed pumps. Codes get set when the ECM gets an out of parameter reading from a sensor. The only way that gasket could cause a code, is if you have a fuel tank pressure sensor. Your Factory Service Manual has a trouble shooting chart to lead you to the cause of the code, without buying unnecessary parts.
RACE ON!!!
Old Mar 10, 2005 | 10:22 AM
Unriced's Avatar
Unriced
Code 54 No fuel sync (camshaft signal) detected during engine cranking
Old Mar 10, 2005 | 10:31 AM
Moxxi's Avatar
Moxxi
I replaced the fuel guage sending unit, and noticed that the gasket was falling apart. The only thing holding it together was the fact that it was sandwiched between the fuel tank and the filler neck. Even if this isn't the 'code 54' problem, it still needs to be replaced.
With Code 54 being a fuel circuit problem, and since the fuel system is supposed to be pressurized, I figured that if the gasket was allowing the fuel pressure to slowly escape (like overnight), this may be my problem.
I can start my car easily if it has ran recently. But let it set overnight, and it may take me turning it over for 4 to 6 seconds before it starts up.
In any case, I will replace the gasket tonight.
What do y'all think?
Old Mar 10, 2005 | 10:45 AM
Moxxi's Avatar
Moxxi
Unriced-
What does this mean? What would I check for, and where?
Old Mar 10, 2005 | 10:58 AM
CFI-EFI's Avatar
CFI-EFI
I think you are trying to combine two different systems. Code 54 is a fuel system ELECTRICAL circuit problem. The the electrical circuit does not get compressed nor does it show a fault code if it isn't. You are trying to combine the fuel system electrical control circuit, with the fuel system fluid circuit. Pressurizing the the air and fuel in the tank does NOT pressurize the electrons in the wires. The code is being set because there is a problem with the electrical components of the system that "report" to the ECM. Not a problem with the environment inside the tank. Again, refer to your HELMS.
RACE ON!!!
Old Mar 10, 2005 | 11:02 AM
Moxxi's Avatar
Moxxi
I don't have a helms. How much does one cost?
Old Mar 10, 2005 | 11:09 AM
Moxxi's Avatar
Moxxi
Old Mar 10, 2005 | 11:13 AM
CFI-EFI's Avatar
CFI-EFI
I have left you links in my last two posts. Try HERE, for a third.
RACE ON!!!
Old Mar 10, 2005 | 11:20 AM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
The generic code 54 is Fuel enable failure, and, yes, it is possible that loss of pressure in the fuel tank could have flagged a sensor to have the CCM show that code. Replace the gasket, reset the code and crank it up.
Old Mar 10, 2005 | 11:40 AM
CFI-EFI's Avatar
CFI-EFI
No Way!!!
Race On!!!
Old Mar 10, 2005 | 12:15 PM
Moxxi's Avatar
Moxxi
I guess we'll find out, one way or the other, tonight.
Old Mar 10, 2005 | 12:26 PM
Hooked on Vettes's Avatar
Hooked on Vettes
You didn't mention the year of your Vette. If this is for a 85, Code 54 is Low Voltage Fuel Pump Circuit.
The purpose for Code 54 is to detect a bad fuel pump relay.
If the engine is running, Code 54 will set if the voltage to the fuel pump is less than 2 volts for 1.5 seconds since the last reference pluse was received from the distributor.
When you turn the key to Run (engine not running) the ECM also expects the Fuel Pump to run for 2 seconds. If it doesn't see 12 volts to the fuel pump, Code 54 will set.
Most likely your problem is a bad fuel pump relay.
Not sure on a 85 but I think it's mounted on the firewall on the passenger side of the power brake booster.
Old Mar 10, 2005 | 01:34 PM
Moxxi's Avatar
Moxxi
Hooked on Vettes-
Sorry about that. Yes, it is an '85 vette.
I replaced the relay about two years ago. Maybe it's time for another one.
Still gonna replace the fuel tank gasket, though. It's really in bad shape.
Everyone, I appreciate the input. Thank you very much.
Old Mar 10, 2005 | 01:37 PM
Frizlefrak's Avatar
Frizlefrak
One last footnote....when reinstalling, ensure the correct orientation of the "notch" in the gasket....upper right. It will fit other ways, but won't seal correctly. Here's some pics that might help.
Old Mar 10, 2005 | 01:59 PM
Moxxi's Avatar
Moxxi
I thought that the notch had to be in the lower right corner.
To fuel tank gasket ???
Old Mar 10, 2005 | 03:07 PM
CFI-EFI's Avatar
CFI-EFI
That is bassakwards. The ECM doesn't EXPECT to see the pump run. The ECM CAUSES the pump to to run. If the ECM doesn't see distributor pulses, indicating the engine is turning (cranking or running) within 2 seconds of ignition "ON" the ECM stops the signal to the fuel pump relay, shutting the pump off.
Also, I never suggested NOT replacing the gasket. I just said that *I* haven't needed to. If it is as screwed up as you say...definitely DO replace the gasket. The fumes that can leak out with a bad gasket can be extremely dangerous. You WILL not cure the cause of your code 54, though. If depressurizing the tank caused a code, you would get one at every fill up.
RACE ON!!!
Old Mar 10, 2005 | 03:27 PM
Moxxi's Avatar
Moxxi
That makes sense.
I wasn't trying to start WW3.
Old Mar 10, 2005 | 04:20 PM
Hooked on Vettes
Were taking about what can cause a Code 54
CFI-EFI You really need to chill out and read what I said instead of quoting partial statements like you have a habit of doing.
When you turn the key to run, it's obvious no distributor pulses will be present so the ECM will only energize the Fuel Pump relay for 2 seconds.
During the 2 second period, if the ECM sees no 12 volts on the Fuel Pump relay output, Code 54 will set.
CFI-EFI You appear by your posts to have a negative additude. Always ready to jump in to a post but offer little if any solutions.
