86 help
Old Mar 10, 2005 | 02:43 PM
eatmydst1234's Avatar
eatmydst1234
Default 86 help
my dad has a malcolm konner edition '86 corvette and had to reset the t/b because it stuck open when backing out of a driveway but every since then the car has had a skip when ingear and under a load the fuel mileage has also gone from about 20 miles per gallon to about 10-15 miles per gallon please help
Old Mar 10, 2005 | 02:48 PM
BlackC6LS3's Avatar
BlackC6LS3
what do you mean by reset? did he set the idle and tps voltage in that order?
Old Mar 10, 2005 | 06:11 PM
JAKE's Avatar
JAKE
Many times this can be caused by a build-up of carbon on the backside of the throttle body butter-flies. The carbon will cause the butterflies to stick.
You'll need to remove the TB and clean off the carbon. That could be all there is causing the problem.
Jake
Old Mar 10, 2005 | 06:47 PM
BlackC6LS3's Avatar
BlackC6LS3
no need to remove the tb, just spray carb cleaner in there till its clean....worked for me
Old Mar 10, 2005 | 07:22 PM
JAKE's Avatar
JAKE
Like always there's more than one way to do something. It's just some ways are better than others.
The best way is to remove the TB though, since none of the gunk you're removing will enter the plenum and perhaps effect the spark plugs and/or 02 sensor down-stream.
At the same time the TB is off, it's a good idea to remove the IAC and clean it too. If the butterflies and carboned, you can bet the IAC is too.
Jake
Old Mar 11, 2005 | 08:33 AM
eatmydst1234
thanx for your help but what i mean my reset is that there is a button in the t/b of the C-4 vettes that resets the tv cable and you reset it by taking the throttle wide open while the car is off and there is a metal button either in the middle of the throttle lever or beside it. but when he reset it the throttle didn't stick anymore but the car runs like crap
Old Mar 11, 2005 | 10:23 AM
CFI-EFI's Avatar
CFI-EFI
Oh Oh!!! What you are describing is NOT the proper way to adjust the TV cable. First, the TV cable adjustment does not affect how the engine runs. Second, if the TV cable isn't adjusted correctly, the transmission can fail, QUICKLY. Your service manual has the adjustment procedure. If you don't have a manual, after you go HERE and order one, do a search. It has been explained many times, on here.
RACE ON!!!
Old Mar 14, 2005 | 08:33 AM
eatmydst1234
didn't think it could hurt anything because that is what GM told us to do. didn't find the procedure in the owners manual or any of the big manuals that supposidly have everything about 84-96 corvettes
Old Mar 14, 2005 | 11:22 AM
CFI-EFI's Avatar
CFI-EFI
OK. It's your car.
BTW, a service manual is different than an owners manual. I gave you a link for the "Factory Service Manual" in my last post...if you care.
RACE ON!!!
Old Mar 16, 2005 | 09:46 AM
eatmydst1234
we have about four or five service manuals for the car were would i be able to find the precedure for ajusting the tv cable the correct way. would it be listed under the tranny section? any help would be greatly appreciated.
Old Mar 16, 2005 | 10:42 AM
CFI-EFI's Avatar
CFI-EFI
That is where it is in MY "Factory Service Manual".
RACE ON!!!
Old Mar 16, 2005 | 12:27 PM
JAKE's Avatar
JAKE
Did you find the resetting procedure?
If not, I'll post it for you.
Jake
Old Mar 16, 2005 | 09:32 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Originally Posted by CFI-EFI
OK. It's your car.
RACE ON!!!
Give the guy a break....
I have a complete adjustment doc, if you email me, I'll send it to ya... pics included on the procedure.
Old Mar 17, 2005 | 01:44 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Real easy ,Just push in the silver thing and feed the cable back twards the fire wall .
After that release silver button and get in the car and mash the gas to the floor and it's set.
To 86 help
