X pipes
Old Mar 10, 2005 | 11:02 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Default X pipes
When putting in headers, many companies see a Y pipe the meets at some sort of X pipe.
How restrictive is this system? Does it make allot of sense to run headers into a common pipe then out to dual? How much of a disadvantage is this over true dual?
Thanks!
Old Mar 11, 2005 | 12:37 AM
cv67's Avatar
cv67
St. Jude Donor '05
I normally run a crossover pipe (on the old school musclecars)around 12-18 inches behind the collector, space permitting. Lots of guys like the X pipe. Only thing that makes me skeptical of them is the turbulence created in the X by two separate paths of exhaust colliding in a small area, then being forced out to whichever pipe. With a crossover, the exhaust continues a straight path, but gets the "pulse relief" you read so much about. I do like the sounds of cars with the X pipe though. On my vette, I just went the 2.5 into 3" back into 2.5" Y. Its not a high horse application, and is probably sufficient.
Old Mar 11, 2005 | 01:52 AM
bogus's Avatar
bogus
The way I figure it, the X-pipe is a killer piece of equipment... NASCAR uses them to get the most power possible. I may not be a big fan, but those dudes know engines...
Old Mar 11, 2005 | 09:46 AM
jsup's Avatar
jsup
So I wouldn't be giving anything up to go from headers to a Y pipe to an X pipe. Seems contridictory to common sense, but OK.
Thanks, now all I need is money.
Old Mar 11, 2005 | 10:01 AM
FELNGR8's Avatar
FELNGR8
I don't see where a Y-pipe fits in with an X-pipe. You have two header collectors, why not bring them directly to an X-pipe? Then obviously out of the X-pipe you have two outputs to take to the rear as duals.
The L98s stock had a Y-pipe to bring the exhaust to a single cat. I don't see any reason to use a Y-pipe on an aftermarket custom exhaust, or to continue to use a Y-pipe on a car with headers.
I have cats on mine so I am politically correct and environmentally sensitive. Still my headers, X-pipe, and duals behind gave me a huge torque boost. And it sounds great to boot.
Look at this for visual reference.
Old Mar 11, 2005 | 10:07 AM
jsup's Avatar
jsup
PERFECT!! THAT IS EXACTLY WHAT I NEEDED!
Thank you.
How's that exhaust working for you? Do you like it? What kind of headers. Hope you don't mind, I downloaded the picture to bring to the exhaust shop.
Did you have to get heated 02 sensors?
what year, trans, motor is that?"
I have a 1990, L-98, auto
Old Mar 11, 2005 | 10:11 AM
cv67's Avatar
cv67
St. Jude Donor '05
FELNGR8-Clean install!
Old Mar 11, 2005 | 10:17 AM
jsup's Avatar
jsup
What specific distinction are you drawing between an X pipe and a crossover? Are you referring to an H pipe as a crossover?
Sorry if I sound stupid, I'm from the old C3 school where we do straight dual. I'm still trying to learn this newer technolgoy.
Old Mar 11, 2005 | 10:36 AM
FELNGR8's Avatar
FELNGR8
The exhaust gives me a big torque boost beginning at about 3100 and doesn't tail off til over 5000. That's a kick you can feel in the butt-o-meter. It sounds more like a fat fender rod than a Corvette, which leaves a lot of people doing a double take as I drive by. It's made with 3 inch Dynomax bullet glass packs, 2 per side.
Those are TPIS headers. The installation was very clean on my LT1, and I reused the EGR pipe so it looks totally emissions legal. With the Hot Cam having internal egr through overlap that probably is nothing but looks.
My car is a 94 so I started with heated O2s. I bought a pair to reinstall when I did the work. I did need the O2 extension cables that TPIS included.
This is a 94 6 speed LT1. Which makes a difference in where the cats can be located. With the auto your exhaust shop will have to put the cats in the tunnel behind the transmission and before the X-pipe.
The L98s were using 2-way catalysts, that's why they have precats and a single large cat after the y-pipe joins. After market high flow cats are 3 way catalysts so one in each pipe is sufficient.
You do have to fit all this around the transmission, and I have a smaller starter motor than some L98s. I'm not sure what you have on the 90.
I would call TPIS directly and not try to buy from their web site. They will fix you up with what works right for your car.
Old Mar 11, 2005 | 04:10 PM
cv67's Avatar
cv67
St. Jude Donor '05
Yes, I was referring to the crossover as an H-Pipe
Old Mar 11, 2005 | 04:31 PM
TIMSPEED's Avatar
TIMSPEED
JSup,
I have an 87 with the L98, although you have a factory smaller starter than I do. When I get home today, I'll put my car up on ramps and take some photo's for you today. I have the Hooker Super Comp's with a custom designed Flowmaster Header-Back exhaust. It consists of 2 Flowmaster Y Collectors, that were cut shorter and had a Dynomax Race bullet put between. So it's basically an X pipe, with a resonator in the center. Really makes a unique exhaust tone, and IMHO flows 100x better than any pre-fab cat-back.
Not to mention, my header-back cost me $300, parts/labor. Although, if I had it to do over, I'd use all Stainless Steel piping, simply for the bling factor.
Old Mar 11, 2005 | 06:01 PM
ClarenceT's Avatar
ClarenceT
It's quite different then what we're dealing with though, but yes they do cross the two pipes together
http://static.howstuffworks.com/gif/muffler-nascar.jpg
Old Mar 11, 2005 | 07:18 PM
jsup's Avatar
jsup
Originally Posted by TIMSPEED
JSup,
Thanks. I have a Power Effects cat back that I really like, and hope to keep. It's practicaly brand new. I am trying to figure out how to get to them from headers. I'm trying to determine if an X pipe is the way to go. It would be easier than trying to configure a complete dual system.
I think the Y pipe will go right to the cat, but I would perfer an X pipe with two cats.
How'd the Hookers bolt up? Any problems with wires on the exhuast, or any other fit problems?
Old Mar 12, 2005 | 09:53 AM
C5Jimmy's Avatar
C5Jimmy
Wow! Thanks FELNGR8, now I'm rethinking my whole exhaust system! Very nice, maybe I should go longtubes while I'm at it?? I was going to go with stock manifolds, Random Tech hi flow cats, x pipe instead of resonator, and back to Magnaflow muffs w/ stock LT1 tips!
I gotta look into TPI headers, and what about Kook's?/ I know they do C5 stuff, but maybe they have C4 headers too! Nice!!!!
I know a shop by me that does UNBELIEVABLE work on exhaust systems,(Doug's Street Custom, Fairlawn, NJ) should be a breeze for him to install!
PS i have a 'vert though, will longtubes be too low, or am i thinking out my azz?? Can't be lower than x brace, right?
jsup, whats up????!!!!
To X pipes
