...the passenger side A/C vents in my 96? I assume you have to remove the "kick plate", which I tried to do once with little luck (using the grab and pull like a **** method), and then unscrew the vent.
Mine is rattling like a sombish, and I'd like to add some rubber washers or weatherstripping-ish material behind it to quiet the interior ride down some.
Thanks in advance...
PS - Oh, and another one... How do I remove the black plastic piece all the way to the front and center of the dash? You know, the one with the little black dome in it? I dropped a radar detector bracket suction-cup through the vent, and need to fish it out...
