Removing Battery
Old Mar 12, 2005 | 06:33 PM
dragonwarrior88's Avatar
dragonwarrior88
Default Removing Battery
I was woundering on how to remove the battery because i found a way but i dont want to scratch it
Old Mar 12, 2005 | 06:37 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
Remove the drivers side fender...
Old Mar 12, 2005 | 06:38 PM
dragonwarrior88
how many screws
Old Mar 12, 2005 | 06:44 PM
rws.1's Avatar
rws.1
checkout this article.. it has step by step instruction for changing a C4 battery
http://www.corvettemagazine.com/2001...ttery/bat1.asp
Old Mar 12, 2005 | 06:51 PM
JAKE's Avatar
JAKE
I've got a ground effects kit that marries to the fender, so I can't use that procedure to remove my battery.
I pop the hood and remove the mud shield by taking out, oh maybe 10 or so screws. I then unscrew the cruise control, three bolts.
Then the battery comes up and out. Just had to do it a few weeks ago when my battery wouldn't hold a charge. Still under 3 year warranty from WalMart.
I killed it though, by leaving the charger on too long on the 10 amp setting. I'd connected the charger while working on the car (painting it, etc.) so I could listen to the CD without killing the battery as I worked. Forgot to turn it off before lights out.
Color me old and forgetful.
Jake
Old Mar 13, 2005 | 10:26 AM
TheCar's Avatar
TheCar
Saw this done on Horsepower TV. The show with the fat guy and the skinny guy that never lets the fat guy drive any of the good cars. Dream car garage I think.
Just remove the top screws and bend the fender down and slide battery out. What a bunch of hacks! Anyway they got it out fast and easy. It was just a racecar probably will get wrecked anyway.
I like Jakes way best!
To Removing Battery
