I just installed my first set of plugs in a corvette today and WOW what fun! Actually they were not as bad as I figured they would be but they rank up there with the most difficult. I put plugs in a 92 firebird that was almost as bad. At 80k miles I didn't think I really needed plugs but the car definately idles smoother with the new ones. I want to put on wires next but that looks like more of a challenge than the plugs!
I used the box wrench for a couple and also a 1/2" ratchet with a shallow socket on the end of the spark plug socket. Next time I am ordering the sidewinder speed wrench. That would have been real nice for #8!
The first time I did my plugs, it took me 3 hours... and #8 took most of that.
After that, I have it down to like 1 hour! Practice makes perfect!!!
The factory AC Delco platinums are junk. They die by 40k miles... total junk.
I like NGK. Very nice plug.
When I change them, I find that a sparkplug socket and a 3/4" offset box wrench is a God send.
When I replaced my factory plugs at 23k miles, half of them were already missing the platinum pucks. I also went with the Iridium plugs, but I really didn't feel any difference.
Way back in the fall of last year, I submitted a longish and detailed step-by-step to C4 Tech Tips, of how I changed wires on my '95 without having to remove the serpentine belt or alternator to do the driver side, which is the difficult side.
It still has not appeared in the C4 Tech Tips. Don't know why, plug wire changing on the LT1 is a frequent topic in C4 Tech/Performance. I figured a detailed tech tip on it would have been welcomed by the admin(s).
I've got two tips in myself and not posted yet. I think this function is inop. I'm not writing anymore until the ones I wrote get in there.
Lone Ranger, can you email me the steps? Wires don't look like much fun at all!
Well, that's just it-- I had typed it directly into the tech tip submission form when I did it, and submited it that way. I don't remember saving it to a file first, but I'll check. It was all fresh in my mind at the time because I typed it up like a day or two after doing the wires twice in one week's time (1st wireset had a defect and had to be refunded, so I got to experience the joy of an LT1 wire change twice back to back)... ...but since then I've slept numerous times and had some beers, too
They are not that difficult to do, you will do some leaning and hugging the front of the engine on the drivers side opti connections. What really helped me was the service manual has wire routing pictures for both sides. Getting the through the right places and making the right turn to the right plug can be a brain teaser. I did the passenger side first.
Should have done it when you did the plugs. You'll need to remove the drive belt and tensioner. The tensioner has a single bolt with a large locator pin on the rear to help seat it on installation.
Oh yes and an 11" bent needle nose pliers make inserting the coil wire in through the water pump housing to the opti. I found that you can aim the wire and start it from the front of alternator then go from behind to seat it on the opti.
I went with Taylor Spiro Pro 8mm existing wire trees and NGK TR55ix. Throttle response is very good with this combo.
If you need images I probably can make some for you.
And you won't... that's the good part - the NGKs won't deteriate over time.
