Aargh, 1 step forward; 2 steps back?
Well, my belt finally gave out on the way home but I felt pretty lucky since I recently ordered & received the very hard to find (locally at least) double-ribbed replacement belt. I went out & put on the new belt, trying to be careful not to break that plastic sensor near the tensioner with my breaker bar....and.... I broke it anyway
First off, what is that sensor down there near the tensioner that looks a lot like the maf plug? Engine coolant temp sensor perhaps? Secondly, I see that it's throwing a code already but can I drive without it until I get a replacement part? Also, I didn't have a good look but it appears to be embedded into the thermostat housing or something else down that way, will I have to yank out all of those parts when I replace it or does it have a nut that allows for it to come out?
Ugh... one day I'll learn to be more careful.
Thanks,
Mark
It's in the water pump. You should be able to wrench it off with channel locks or something. I think it's a 5/8ths deep, but I don't remember.
What you can do is RTV the plug to the sensor. I did that... and it holds pretty good.
