Corvette Central... but hold on to your headlights... the price is a shocker!!!
HEADLIGHT - NON-POPUP (ND) Part number 444317 Price $999.00
You can have a custom and more aggressive look for your C4 with Breathless Performance's new non-popup headlight system. Includes brackets made from 60-61 aircraft aluminum with DOT-approved low beams mounted using a bubble level for adjustments. CATS performance high beam lights, and headlight tubs manufactured of ABS with a tough acrylic molded lens cover. Allow 20 minutes to remove the original headlights and about 1-2 hours to install the new pre-mounted system. Low beam wattage is 130, with high beam wattage rated at 280.
There was a post about this in the General Questions forum a while back. I'm planning on buying the kit from C5West.com. Their headlight kit has the double bubble look. See pic but try to ignore all the other mods. I know.....it looks like Shrek.
Since this is a track car, I'm not as concerned with the looks (as long as it doesn't look stupid, of course, I don't want the 911 driver to laugh when I come up behind him quickly) as the weight...ever weigh the stock HL assembly? Cripes, it's a boat anchor.
I think I'm going to rig something up with the running lights in the bumper. Perhaps stick some hi-intensity lights in there and just cap off the current light locations.
I'll post some pics if I go this route and anyone's interested. Probably not OK for a street car, but should get me what I need. Won't be able to illuminate very far in front of the car, though.
