4+3 questions
I am trying to diagnose the problem with it and don't know what conditions trigger what. I changed the fluid in it about a month ago. When I push the button most of the times the car works correctly, the light turns on and the car shifts into overdrive. Sometimes when I push the button the light comes on but the car will not shift into overdrive or it will shift in and out. Sometimes after it goes into overdrive and I am driving at a steady pace the car will shift in and out of overdrive. When this is happening the overdrive light stays lit and doesn't go out. If the car is in overdrive and I floor it the car shifts to direct drive and the light turns off. Not sure if this is a fluid, relay/connector or some other problem. Anyone have any ideas?
Check out this link to see how yours is supposed to work compared to how it works...
http://www.5speeds.com/43table.htm
frank
The other is if the wire from the o/d relay to the unit is shorting or coming loose. I had problems with the stupid plastic plug shrinking from heat and coming undone. After the 2nd time I ziptied and taped the damn thing on there.
The unit is supposed to downshift automatically when you punch it in 4th gear. The later years also downshift in 2nd and 3rd.
