Stealth Ram anyone?
They offer the fuel rails and all the other bits and pieces. If I come across the link - I believe I saved it - I'll post it.
Jake
John
How did you go about installing yours?
Thanks,
Jake
yedi
http://www.crossedflags.com/nuke/htm...wtopic&t=10585
http://www.stealthram.com/phpBB2/index.php
Thanks,
Jake
John
Where did you get your custom plenum? Was it worth the change?
John
John
What say we mill the top of the base 5/16", then both the bottom and top of the plenum 5/16". That's be 15/16", which should be more than enough.
I'm thinking that it would be better to take the metal from all three locations rather than reduce only the plenum volume to get the needed height.
I've never seen one close up to know for sure, but I'm wondering if that'll work.
Good link, Steve. It showed me the distributor that's needed to clear the intake. Thanks for that.
I'm wondering, too, if a mount can be fabricated to allow the use of the stock fuel rails. Seems that a braided hose can be used for the cross-over.
Summit sells the intake and plenum for $300, then I'd be looking at another $175 or so for the rails and another 200+ for the distributor and coil.
Adds up in a hurry.
Jake
