I've never heard of this before and would like to know more. Using the starter fluid method, I know you spray it around the suspect leak area. Using smoke, where exactly are you directing the smoke? How does blowing smoke into the TB confirm a leak? If you're looking for the smoke to come out of the exhaust, I can see how that would indicate vac leak. But, how do you pinpoint the source of the leak?
On a related note, my LT idles a bit higher than I think it should, but it idles smooth as a kitten. (Sorry, Sweet90). I'm presuming that a minor vac leak could account for this? The IAC and TB are clean.
With the engine off I just had a smoker blow smoke into the tube which was sealed by the rag. It took half a cig to fill up the intake and I shined a light around looking for smoke leaks. I ended up finding a small leak, I could clearly see the smoke escaping.
That's a new one on me! I guess you're not concerned about any water getting into the cylinders? I also assume water helps to enhance stumbling to confirm location of the leak?
Obviously, it won't smooth things out like propane would.
Between propane and starter fluild, I've always preferred the former. starter fluid can start a fire where propane....The worst thing I can thick of would be the torch lighting. Just be quick to redirect if it does. You can't be quick enough for starter fluid.
Yep, plain ole water from the garden hose, spray bottle or anything else similar. Been around since Hector was a Pup; I've used water for decades.
Not looking to "smooth things out" but, instead am looking for just the opposite: For the engine to stumble and/or white smoke out of the muffler.
Water entering the cylinders is exactly what I'm hoping to find; that'll tell me where the vacuum leak is located.
Other use is to spray water directly into the TB or carb to steam clean the pistons/combustion chambers and valves. That, too, has been around for decades.
Of course nowadays companies want you to buy their "special" stuff to do basically the same thing. You know, "Add "X" amount to the gas and "X" amount to the oil and with the engine running add"X" amount to the power brake vaccum hose"
I've never had any luck with propane or water. I've never tried smoke, it sounds very intriguing. I've had good luck with carb cleaner and the mechanics I know use the same thing.
using water is old school and works. Been around since who knows when. No, it doesnt hurt anything...heck, they used to pour water (slowly) down carbs to clean up the valves.
Great thread! Found this video on YouTube http://www.youtube.com/watch?v=FfiQ7qWiG-M Doesn't show what smoke machine is being used but shows how it finds leaks. Seems like a smoke machine could be built pretty cheap, but really have to have an accurate air regulator and gauge to make sure you don't put too much pressure into the vacuum lines. I think I'm going to make this my "homemade tool" project for the summer.
