Anyone running a heated 02 on a system that was previously a 1 wire? Has anyone noticed any MPG increase or other benefits from running a 3 wire vs. a 1 wire? If so, does anyone perhaps have a part number handy on a 3 wire.
The two systems I am looking to do this on are an 85 Corvette and an 86 Corvette setup in another vehicle.
Thanks a bunch. I appreciate the help and information.
Dylan
Nope, makes no difference. A heated sensor just prevents the system from dropping out of closed loop at idle when long tube headers are used, as when you stop at a traffic light.
I agree with JAKE, they're supposed to operate the same way. but other threads have hinted at better idle and a slight increase in MPG from the non-heated types. Whether that's because the sensors (that were replaced by the heated kind) were fouled and inaccurate or because the replacements were simply of better quality - or even a placebo effect of sorts - I do not know.
I would think that the heated O2 was implimented for a reason and I suspect that extended idle/cold starts/coasting situations might benefit from the heated sensor.
A heated O2 wont make a difference in gas mileage compared to a regular sensor, its only going to stay in closed loop when the other would drop out of closed loop.
You'll see more of a difference in just changing out the old sensor for a new one, than switching from regular to heated.
The only difference in the sensors is an extra ceramic shielding that keeps the sensor element warm and smaller openings to retain that heat.
