Window guide replacement
Old Mar 22, 2005 | 02:58 PM
Silver.Bullet's Avatar
Silver.Bullet
3rd Gear
Default Window guide replacement
'96 passenger side window guide...bolted through the lower forward end of the window glass is a window guide. Mine has broken and must be replaced; the guide is bolted through the glass to a sort of threaded washer on the far side (outside) of the the glass. I cannot loosen the through the glass bolt because the washer on the other side turns freely and I cannot find a way to hold it firm enough to loosen the bolt. I have tried using a C-clamp but I am afraid of cracking the glass. I have not disassembled the door other then to remove the inner door panel, so there isn't much working room. Does anyone know of a way to loosen that bolt without taking the door completely apart? If taking the door apart is the only way, how do I go about doing it? I assume the weather stripping must be removed...can it be resused, or should it be replaced? Mine is in good condition. Even if I take the door apart I will still have the prolem of holding that pesky washer. I could sure use some help on this one.
