Short throw shifter
Old Mar 22, 2005 | 05:12 PM
RED LT4's Avatar
RED LT4
Default Short throw shifter
I have my transmission out at this time because I am doing a rebuild on a 96 LT4. I have a extra shift handle that is a stock handle just like the one in my 6 speed. I was thinking about cutting it shorter and threading it for the shift ****. Has anyone done or heard of this? Just dont have the money to buy a new $150 short shift handle because it is all going back into the rebuild, need to get some new coated headers!! Thanks for any info
Old Mar 23, 2005 | 11:30 AM
cresus's Avatar
cresus
I am replacing my stock shifter with a short throw that I built in the machine shop. I can check it out when I pull the other one off of the transmission to see if the only main difference is the shaft length. Seems like it should work the same just not have the postive feel between gears.
Old Mar 23, 2005 | 11:35 AM
RED LT4's Avatar
RED LT4
Just trying to figure out if it is worth the time to do it? I have the trans out at this time so it would be the time to do it
Old Mar 23, 2005 | 11:45 AM
RED LT4's Avatar
RED LT4
Old Mar 23, 2005 | 12:31 PM
500hp's Avatar
500hp
As I understand it, to get a shorter, quicker shifter, you need to INCREASE the distance between the shifter's pivot point and where the end of shifter connects to the shift rod/rail in the transmission. By just lowering the point at which you grasp the shifter, you may shorten the 'throw' by not having to swing your arm as far as before, but I believe this increases the effort needed shift without actually changing the amount of travel below the pivot point where the shifting actually takes place. You appear to do less shifting, but it doesn't effectively translate into a much quicker shift. I agree $150-$200 is too much for a shifter stick and a couple ounces of hardware, but they are a definite improvement and are a breeze to install with the trans on the ground. Sell a kidney and buy a Hurst.
Old Mar 23, 2005 | 01:47 PM
SharkB4C4's Avatar
SharkB4C4
Plus, the stock stick will still have that "rubbery" feel to it due the 2-piece design.
Old Mar 25, 2005 | 07:55 AM
bmann08's Avatar
bmann08
Cruising
I second this. I have the Hurst billet shifter and absolutely love it!
Old Mar 25, 2005 | 07:58 AM
Nathan Plemons's Avatar
Nathan Plemons
Personally I prefer the B&M. If you want your shifts to be rock solid. The Hurst just isn't really that much of an improvement over stock.
Ultimately though it's a love / hate thing. If you love B&M you hate Hurst and vice versa. The one thing that we can all agree on though is that the stock shifter sucks.
The best advice would be to try and drive one of each before you make your decision.
Old Mar 25, 2005 | 09:01 PM
Strick's Avatar
Strick
This is where you are wrong. The difference is night and day.
Now this is good advice.
Old Mar 25, 2005 | 09:53 PM
JB666's Avatar
JB666
I agree with your advice. The only thing I don't agree with is that the Hurst isn't much of an improvement over stock - it's a HUGE difference. You completely lose the sloppy shift feeling - it's rock solid, and VERY tight..
I liked the feel of both shifters, to be honest, I just stumbled on a good deal on the Hurst on EBay, so that was what I got
To Short throw shifter
