Performance Axle ?
Old Mar 22, 2005 | 06:45 PM
boatman's Avatar
boatman
Default Performance Axle ?
The sticker on my 89R with AT has the performance axle option on it for $22.00. It says, performance axle ratio.
Looking at the build sheet, it has the G92 performance ratio axle, and right abovt that, GU2 - 2.73 ratio axle.
Why the option ? What did you get if you did not check off the GU2 ?
2.73 ring and pinion does not sound like too much performance.
Am I missing something? I do not know the C4 mechanics that well.
Boatman
Old Mar 22, 2005 | 06:59 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
There were 2 different performance ratios available. 2.73 and 3.07. Base ratio was 2.59
Old Mar 22, 2005 | 09:34 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
For the `89 model year;
standard ratio for autos was 2.59
perf-axle for convertibles was 2.73
perf-axle for coupes was 3.07
Old Mar 23, 2005 | 12:42 AM
Mo_Bandy's Avatar
Mo_Bandy
Yes , G 92 is 3.07....
Mo
Old Mar 23, 2005 | 09:29 AM
dndrsn's Avatar
dndrsn
Default Options
Old Mar 23, 2005 | 10:20 AM
c4cruiser's Avatar
c4cruiser
The G92 only means that the car had an optional performance axle ratio installed. The specific auto tranny performance axle ratio depended on whether the car was a coupe or a vert. Typically, it was G44 3.07 for a coupe or GU2 2.73 for a vert. 6-speed cars got different specific ratios based on the body style but the G92 still refered to a "performance axle"
GM sort of confused things with two RPO codes for a performance axle.
Old Mar 23, 2005 | 11:33 AM
vader86's Avatar
vader86
The G92 is a useless code, it means nothing by itself.
The code it triggers is the axle code, for you it was 2.73 which is not terrible for the L98.
You wouldve gotten 2.59 had the buyer not checked off G92, although there were some years where you could get the 2.73 or 3.07s without getting the G92.
To Performance Axle ?
