Remove old antenna mast
Old Mar 22, 2005 | 09:04 PM
LS6-RAT's Avatar
LS6-RAT
Cruising
Default Remove old antenna mast
I'm having a problem removing the old antenna mast. A while back the top section of the mast was broken. I removed the broken piece along with the nylon cable. I can't seem to remove the base of the old antenna from the motor. Really don't want to remove the entire motor. I've removed the rubber grommet and the plastic ring. Can anyone give me some ideas to try? I appreciate any help. The car is a '93 vert.
