Redline synthetic ATF , 4 types?
Old Mar 23, 2005 | 09:19 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Default Redline synthetic ATF , 4 types?
I went to get some Synthetic ATF. I have used Mobil 1 for years, and I have looked and its not carried here anymore in Hawaii. SO, I went searching, and found Redline ATF, but they have four types for GM's. D4 (meets GL-4, Dexron 3, Mercon and Mercon V, Synthetic ATF (Dexron 2 only),High Temp ATF(same as synthetic but can handle 70 degrees F higher temps, and Racing ATF (synthetic for automatic/manuals which need the psoitive shifting of Type-f(ford I believe, and contains no additives, and a higher viscosity at higher temps)
So, what would you recommend here in Hawaii. Ihave a 2800 rpm Vigilante, Trans-go shift kit, and 3.75 gears, and a medium cooler.
I also am trying to find Amsoil, and will take recommendations for them also.
Old Mar 24, 2005 | 11:47 AM
steve40th's Avatar
steve40th
ttt
Old Mar 24, 2005 | 11:49 AM
bogus's Avatar
bogus
Any ATF that meets DEXRON 3 standards are ok.
To Redline synthetic ATF , 4 types?
