Lost My Keyed Lugnut Socket!!!
Old Mar 24, 2005 | 12:41 AM
zeitgeist57's Avatar
zeitgeist57
Default Lost My Keyed Lugnut Socket!!!
I thought Firestone still had it after an alignment four months ago, but I'm picking up new wheels and tires and for the life of me I can't seem to locate the one lug nut socket for the keyed lugnut on each on the wheels on my '95.
What have you done in the past when it's happened to you? What do other people do??? The local Chebby dealership said they could air-chisel the old one off, but if I were to be that drastic, I wouldn't bother to pay someone else to do it!
Please help! Thanks!
CLay
Old Mar 24, 2005 | 12:44 AM
scorp508's Avatar
scorp508
I used a cheap 1/2" drive 12-point 13/16" socket and tapped it on lightly with a hammer. It grabs enough turn the lugnut. When you get it off use a 3/8" extension through the 1/2" hole in the socket to tap the lugnut out.
Old Mar 24, 2005 | 01:11 AM
nitronick's Avatar
nitronick
Active Streak: 90 Days
If you're not in a hurry, take a look in your paperwork(owners manual, etc), and look for the McGard key card. It will have the code "color" your lock requires. There will be a phone number on there for you to call to place your order.
On the other hand, any reputable tire shop should have a tool kit to remove the locks. Shouldn't cost too much.
Old Mar 24, 2005 | 01:22 AM
VenkmanP's Avatar
VenkmanP
NTB removed a set for me for free a couple months ago.
If you have an impact wrench you can buy the extractors from an auto parts store and do it yourself.
Old Mar 24, 2005 | 01:34 AM
kopbet89c4's Avatar
kopbet89c4
I tried that one technique on my Honda with a heptagonal lock nut and actually ended up stripping it to the point of getting my oxyacetylene torch out. Got the wheels off but had to replace 1 stud per wheel. Took out 6 hours of my day.
The irony is that the heptagon key was wedged right under my seat after I took off my seat covers for cleaning. I can be so stupid at times.
Old Mar 24, 2005 | 03:42 AM
randy814u's Avatar
randy814u
I took mine to a welding shop. He welded a rod on the end of it and then put a pipe wrench on the end of the rod. It took less then 10 minutes and was 20 bucks.
Old Mar 24, 2005 | 08:18 AM
Unriced's Avatar
Unriced
Monkeys at a shop I *used* to go to wrecked mine and then
wouldnt pay to have em taken off etc etc.. They have soft
sockets for this type of thing.. There are kits to get them
off and not ruin them.. Real easy. Dont sweat it, as mentioned
above, any good shop should have one around.. Good Luck
Old Mar 24, 2005 | 08:27 AM
scorp508's Avatar
scorp508
Originally Posted by Unriced
They have soft
Yep, my father sells these things a lot. Its kind of like a socket with teeth that grip when turned against the lugnut.
Old Mar 24, 2005 | 09:59 AM
ralph's Avatar
ralph
Any respectable car thief can get them off in seconds. Which, of course, makes them virtually useless as a thief deterent.
Old Mar 24, 2005 | 10:21 AM
scorp508's Avatar
scorp508
Originally Posted by ralph
.....respectable car thief ......
Old Mar 24, 2005 | 10:32 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Eastwood sells a set of "sockets" just for this.
They probably sell a ton of these to those respectable car thieves....
Larry
code5coupe
Old Mar 24, 2005 | 10:37 AM
LaVidaLoca's Avatar
LaVidaLoca
One of my friends is a tire dealer and he agrees totally. The locking lugs can be defeated with minimal effort. Which brings up the situation we have here; it is only the owner that gets slowed down by these things
One other draw back is that if you have 11" rear rims like I do, the holes are too narrow and deep for most of the extractors that fit over the locking lug. So you may end up damaging a nice set of rims in the attempt to get them off.
I had a similar experience and after I finally got mine off I threw them all in the trash and went with regular acorn lug nuts without the plastic covers (which are another PITA).
Old Mar 24, 2005 | 10:57 AM
skybolt31's Avatar
skybolt31
I agree. In addition to respectable car thieves having their own methods, I am sure they know that the key to the lock is somewhere in the car. I suppose I could have taken it with me whenever I left the car, but it stayed in the console. So I took them off and have regular lugs, fortunately, stock 86 wheels don't seem to be a high theft item!
Old Mar 24, 2005 | 11:13 AM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
go to sears and pick up a damaged nut remover set for $20
here's a link: http://www.sears.com/sr/javasr/produ...id=00952160000
there's even a video you can watch
Old Mar 24, 2005 | 11:18 AM
KEVS_L98's Avatar
KEVS_L98
I have just done the same thing and Discount Tire will remove them for $10 a pop, not too expensive if you get a flat on your way home and you can't get the wheel off .
Old Mar 24, 2005 | 01:40 PM
kopbet89c4's Avatar
kopbet89c4
Good idea! I'm on my way to Sears and will pick that up along the way after I drop off my pressure washer to get repaired/replaced!!
Old Mar 24, 2005 | 02:13 PM
PierEagle's Avatar
PierEagle
And we continue to make it even easier for them. Just saw a local Sears ad in the paper for 4 or 5 sockets for $19.95 that will "remove most wheel locks".
Old Mar 24, 2005 | 04:02 PM
umfan's Avatar
umfan
I had a similar problem when I found the alignment shop had stripped the removal tool. I found a new set cheap on ebay, so I took my Dremel with a carbide tip bit and cut a slot in the bolt. After the slots were cut I just used screw driver to back them out.
To Lost My Keyed Lugnut Socket!!!
