Runs like crap when hot . . .
When it's cold it seems to run ok. Recently I was getting hesitation under hard acceleration. It got worse to the point where it hesitates real bad the hotter it gets. Even very light acceleration causes it to hesistate. It gets to the point where it hardly wants to idle.
When it's cold it's ok.
Fuel pump? I just changed the fuel filter.
I've got 6-mos on a new Dynaspark, plugs, and wires. Just changed out the O2 sensors as well.
Are a coil and ignition module Autozone type items?
Two different animals and the one the ECM uses is critical for the ECM to send the correct timing and fuel signals.
Jake
Jake
What other sensor would the coolant gauge use?
What size are the stock size for them?
Changing parts in the hope of hitting on the one that's causing the problem isn't the way to go about it.
A data logger running when the problem occurs will identify which sensor is out of range.
Changing injectors may well be an unnecessary expense, not to mention the work involved. Just use a meter to check the resistance; your injectors may well be fine.
Why spend hundreds of dollars and many hours of work changing injectors only to find that the engine still "runs like crap". You'll still have to find and fix the cause after all that.
Please, don't fall into the trap that so many others have, (becoming a parts changer). I wish I had a dollar for every post I've read - "I've changed this, and changed that and changed the other, but still . . ."
How'd you feel about a doctor you visited complaining of a headache and he immediately fired up the operating room to do brain surgery on you?
Same principle, run some tests, check for proper operation of the parts and sensors, find the one(s) that's not performing as it should, then repair/replace it.
A ScanTool will give you most of the information you'll need. A test light and a voltmeter will give the rest.
Just my suggestion.
Jake
My car is 13 years old and other than the tires, brake pads, opti, belt, hoses, water pump, plugs and wires, o2 sensors, and the temp sensor it is all original at 145K miles.
I just now bought rotors, hubs, and bearings which I was going to change until it started running crappy. Yep, the current units are stock.
Oh yeah, I did change the u-joints on the half shafts and one clutch. Still not bad for a '92.
I just figured with some parts, they probably should be changed after that many miles. I was considering a new set of injectors before this problem occured, which is why I said as I did. If they're ok, I guess I could just get them cleaned.
I just started it and it freaked out on me. Ran ok for a second, then the tach started jumping.
I shut it off, turned it back on. Running horrible, backfiring. It will stabalize some, but reving it up in neutral hesitates bad.
Sounds more like an Opti, doesn't it?
No codes.
I'll run what tests I can and see what comes up.
The RPM data comes right off the tach filter, which gets its data from the coil/ignitor assembly.
Once the tach starts wacking, then I would look at the coil. Considering it's getting worse, I am more convinced it's at the coil/ignitor.
Call Chris at Superior Chevy, 1.800.728.8267, tell him you are a forum member...
I am sure you know the drill.
I am sure you know the drill.With a voltmeter, engine off, check that the voltage increases in a steady fashion as you open the TB butterflies by hand. There should be no sudden jumps or dip in the voltage readings.
From what I've read, a digital volt meter ISN'T the best for this kind of test. If DVM is all you have though, give it a try.
Jake
