over heating Issue
I have a 160 therm., 2 bottles of water wetter in the radiator, have had the front of the radiator cleaned several times, Have cloth header wrap on headers to reduce engine compartment temp. and had the radiator flushed with It still Installed on my car.
It's a 1991 with 71000 miles on the radiator. Do I just need a new radiator or does the 383 stroker make too much heat.
The thermostat isn't helping anything. Although it doesn't hurt, either. Was the radiator cleaned out from between it and the condenser? This is best done by removing the rad. Does the digital read out agree with the gauge, if you have both? Otherwise, have you verified that it is really that hot? If the cooling system hasn't been well maintained over the years the radiator COULD be partially blocked. Before replacing it, you could pull it and have a radiator shop do a flow test. My '84 has the original radiator core, and it works very well. The only other item, which wasn't addressed, is the fans. Are they coming on at the appropriate temps?
RACE ON!!!
I also have a breathless perf. vortech ram air Induction. Could that disrupt air flow to the radiator?
Well, long story short, when I took the car in to be detailed, they killed the optispark, and I had it changed out. The dealer said "Your water pump should probably be replaced as preventative maintenance". So, I did it.
My car ran ~ 20 deg cooler with the new pump.
Now, with my Mez pump, I have the opposite problem- in the spring/winter, I cant get the water temp over 165-170, and in the summer, it barely goes past 180. Guess that 160 therm was a little bit much??
I felt the fan temp. and it was not all that hot so I replaced the thermostat with a 180 deg stat.
I boiled it first and sure enough it opened at 180.
the one I took out only slightly opened at about 230.
You do mention having had the front of the radiator cleaned several times, but that is not the same as pulling the radiator and washing the fins clean of road grime. If you remove the radiator and scrub all of the fins from both sides with a simple green and water mix using a SOFT brush you might se a big difference. Imagine if you never washed your car's paint. How dirty and grimey do you think it would get after a few years? Well, that type of grime can build up on the fins too. Clean them completely and remove any grimey insulating layer. Also, use a small flat bladed screwdriver to carefully straighten every bent fin. The C4 doesn't have an oversize radiator as it is, and with a 383 you want every fin possible working for you.
If you pull the radiator to do a thorough cleaning, I'd follow CFI's advice and have it cheked for internal blockage at the same time.
A new pump will cool better than one with alot of miles on it. Seen it several times myself.
The Meziere is a different story. As with any non-stock pump, it has a different impeller, a different housing, and runs at a different speed. I am not saying that different pumps don't perform differently, what I am saying is that a mechanically driven pump doesn't deteriorate in efficiency over time.
RACE ON!!!
They may very well have changed out the coolant when they changed the water pump. I am not sure, as this was before I was doing my own work on my car.
However, I do know they didn't touch the radiator. I had noticed that I had a bit of a birds nest in there shortly before the opti and water pump were replaced. I thought this might have been what was causing me to run hot (230-240). However, after they changed out the water pump, it was running 210-220 (weather was about the same) but the "birds nest" was still between the radiator and radiator shroud.
If I remember correctly, the reason for replacing the pump was that the bearings were on their way out. I hadn't noticed any nosies coming from the pump before that.
As for the Mez pump- I do realize it is a WHOLE different ball game. Just need to get the car to run a little warmer (~185-195F for my oil temp, isn't high enough IMHO.. I'm shooting for 200-210).
If it wasn't making noise, I'm curious how they determined that the bearings were bad. Maybe they were just trying to defer some of the costs of a "free" opti replacement? Or did they only charge you the cost of the pump?
I would still like to be enlightened, logically, on how a mechanically driven water pump loses performance with age. I can't see it, but I'll be happy to listen.
I think the stock stat for your car is a 180*. That should help.
RACE ON!!!
WP was replaced 2 years ago.
I've noticed that the a/c clutch is engaged even when the a/c is shut off.
What the hell is going on???
RACE ON!!!
). But, if the impeller lost the angle of "attack" due to either buildup or a bent impeller blade, you could end up with cavitation, which would greatly reduce the flow of the pump. It is actually pretty startling how small a change in a blade can cause cavitation.Another possibility, if the bearings were going, is that there was a small wobble in the impeller. Even a wobble small enough not to be heard to the untrained (my) ear, could also cause cavitation, and reduce flow by quite a bit.
