H14 code on LT1
Old Mar 25, 2005 | 02:48 PM
redvetteC4's Avatar
redvetteC4
Default H14 code on LT1
Does anybody know what this code means on a '92 LT1. There doesn't seem to be anything majorly wrong with the car I just checked the codes and this is the one it gave me. Thanks
Old Mar 25, 2005 | 03:00 PM
bogus's Avatar
bogus
OHMYGOD!!! THE DREADED H14!!! Ahhhhh!!!!!!!!!!!!!! your engine is going to explode!!!!!
considering you got this code from the CCM (reading speedo codes), which module?
For module 1.0 - CCM - it means Driver Information Switches Shorted to Ground.
For module 4.0 - ECM - it means Coolant Temp Sensor Voltage low (High temp read).
For module 9.0 - EBCM - no code 14 exists.
My guess? Your car overheated once.
hope this helps!
