anti-lock brake light on
Old Mar 26, 2005 | 12:24 PM
bowersock's Avatar
bowersock
St. Jude Donor '05
Default anti-lock brake light on
Any suggestions why the anti-lock brake warning light would be on?
Recently changed to a big brake kit, new rear calipers, new brake lines,brake bias spring-etc------
Roger
Old Mar 26, 2005 | 12:28 PM
scorp508's Avatar
scorp508
Make sure your wheel bearings are good and tight w/o any looseness in them. Spray some parts cleaner over the ABS sensors in each knuckle. Also make sure the wires didn't get unplugged to them too.
Pete K's Avatar
Pete K
I would look carefully at the wheel sensors. They are easily damaged.
Old Mar 26, 2005 | 03:31 PM
umfan's Avatar
umfan
I had a the same problem. In an old post somebody had recommended replacing the pump relay (14105967) or the valve relay (12513302). They are located on the pump housing under the driver side rear storage bin. The price for the both relays on gmpartsdirect.com was about $50, so I replaced both. Antilocks are now working again, and it only took about 15 minutes.
Old Mar 26, 2005 | 07:04 PM
bowersock's Avatar
bowersock
St. Jude Donor '05
Default anti-lock
rencently had all parts off---should i check and see if they are not connected first?
Old Mar 26, 2005 | 07:11 PM
JAKE's Avatar
JAKE
Roger
I just fixed my Anti-Lock dash light a couple of days ago, so I can fill you in on all I did to find the cause.
What year is your car?
Jake
To anti-lock brake light on
