Dana 44 question
Old Mar 26, 2005 | 09:46 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
Default Dana 44 question
I found this Dana 44 on ebay and was wondering what the difference between the 84 - 87 rears were as compared to the 88-96. Can this work in a later model?
Old Mar 26, 2005 | 11:26 PM
Pete K's Avatar
Pete K
The 4 bolts used to hold the lower strut rods( camber ?) at the 5 and 7 oclock positions are smaller diameter on the pre 88 years. To use an earlier model in a later year will involve drilling these 4 holes slightly larger to fit your 88 and later bolts. The exact size escapes me as it has been a few years. Match up the shank of your bolt for the snug fitting drill bit. Dont drill the hole too large as it will allow the brackets to deflect under load.
Old Mar 27, 2005 | 09:17 AM
MrNuke's Avatar
MrNuke
I put a D44 from a '95 vette into my '85.. Absolutely NO difference or fabrication was needed. (Although I replaced the whole rear-end, suspension and everything, so maybe that's why)
To Dana 44 question
