mouse in my rearend
Old Mar 27, 2005 | 03:47 PM
RED95CONVLUVER's Avatar
RED95CONVLUVER
Default mouse in my rearend
i have a mouse sounding squeak coming from my right side of my rear end /axle shaft area. I thought it was rear disc brake issues at 1st but its not. Is it a u-joint on my right side axle shaft maybe?? it does tend to stop when i hit the brake... I replaced the rear brakes and it didnt change the squeak..thanks all
Old Mar 27, 2005 | 03:49 PM
jabez's Avatar
jabez
I heard of gerbils but a mouse? Whatever turns you on..
Old Mar 27, 2005 | 03:51 PM
JackDidley's Avatar
JackDidley
I believe you have figured it out. Ive killed a lot of Vette u joints and the first sign is usually a squeeek squeeeeek squeeeeek.
Old Mar 27, 2005 | 04:07 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
I was thinking the same thing as I read it
Old Mar 27, 2005 | 05:11 PM
Steel Blue 91's Avatar
Steel Blue 91
Thought I had strayed over into Off Topic.
Check the U joints. That's my bet.
To mouse in my rearend
