twin turbo progress
Old Mar 28, 2005 | 01:27 PM
Fatt Vette's Avatar
Fatt Vette
Default twin turbo progress
Well Folks, here is the progress I have made over the past few weeks. My digital camera is a really cheap model, so please forgive the horrid picture quality.
I still have a lot to do!! At the least, I finally got started.
http://members.***.net/mdawes/twin%20turbo
Old Mar 28, 2005 | 01:56 PM
Baldturbofreak's Avatar
Baldturbofreak
Off to a grreat start! intakes may be a bit tricky, maybe try using the front crossmember as an airbox lika a callaway. That section of the frame is normal old mild steel so feel free to weld on it!
Old Mar 28, 2005 | 02:33 PM
LPDesRoche's Avatar
LPDesRoche
Looks great! Now for the cold side piping......keep us posted.
Old Mar 28, 2005 | 04:32 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
How are you getting oil to and from the turbos?
Old Mar 28, 2005 | 05:01 PM
Fatt Vette's Avatar
Fatt Vette
My plan is to use engine oil presuure on the inlet side. The outlets will run into a tank and be pumped up to the valve cover by a Tilton Engineering diaphram pump.
Old Mar 28, 2005 | 05:40 PM
mn_vette's Avatar
mn_vette
what are you going to do for a tank? Those turbo's hang pretty low, How much ground clearance would you have to put a tank below them?
Old Mar 28, 2005 | 08:03 PM
dr.juice's Avatar
dr.juice
Well Fatt Vette, looks very nice.
Good job!! What kind of turbo's are those.
Good luck.....
Old Mar 28, 2005 | 09:11 PM
Fatt Vette's Avatar
Fatt Vette
The turbos are even with the bottoms of the frame rails, so hopefully we won't hit anything. The tank is made from a piece of 2.5 inch pipe, which will be laid under the oil pan. I hope to have pics of it up soon.
Old Mar 28, 2005 | 09:13 PM
Fatt Vette's Avatar
Fatt Vette
Good luck.....
The turbos are big T3's; .82 A/R, stage one turbines and .60 A/R, 60 trim compressors, oil and water center sections.
Old Mar 29, 2005 | 01:29 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
down low makes for a neat installation.
Best of luck with it.
Old Mar 29, 2005 | 02:26 PM
krivera's Avatar
krivera
looks great!
Old Mar 30, 2005 | 04:51 PM
vette_tweak's Avatar
vette_tweak
Did you cut up the floor / trans tunnel to get those turbo to fit?
Old Mar 30, 2005 | 08:12 PM
Fatt Vette's Avatar
Fatt Vette
No, the turbos fit with no mods to the floor pan . The passenger side was very tight, but the driverside had ample room.
Old Mar 30, 2005 | 11:27 PM
Mo_Bandy's Avatar
Mo_Bandy
Very nice start...
Mo
Old Mar 30, 2005 | 11:58 PM
lcvette's Avatar
lcvette
looks awesome man!! I spent this evening rounding up some more cut off discs for my chop saw, and finishing some job work...phoooey..lol tomorrow night its game on again, gotta get rockin like you man.. your moving right along.. keep up the great work and keep those pictures rolling in man!
Chris
Old Apr 8, 2005 | 08:11 PM
comp94's Avatar
comp94
Man that set up looks great. I was thinking of mounting a couple of t3/4's the same way except i was going to use the stock manifolds and down pipes instead of making headers. It makes me want to build a twin turbo set up my self. Good luck with it
Old Apr 17, 2005 | 11:42 PM
bigcityvette's Avatar
bigcityvette
How much hp will each turbo support?
To twin turbo progress
Old Apr 30, 2005 | 12:24 AM
bigcityvette
Hello?????
Maybe you missed my question.
Old Apr 30, 2005 | 01:45 AM
Fatt Vette's Avatar
Fatt Vette
Sorry,
I am not certain what the max they are capable of is, I hope to get 75 HP a piece out of them.
Old Apr 30, 2005 | 08:44 AM
bigcityvette
ide imagine they support more than 75 hp each unless you plan on running very low boost levels.
