100 hp
Old Mar 28, 2005 | 05:47 PM
ot180's Avatar
ot180
Default 100 hp
Hi,
im new to the corvette scene. I have a 94 convert 6 speed. 100% stock. 54k miles. Im looking to add 75-100 hp. Whats the best way to do with without nos? I have about a $2500-3000 budget.
thanks
Old Mar 28, 2005 | 05:50 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
It would take every bit of that money to add that kind of power.
You'd be looking at porting heads, intake, new cam, long tube headers for sure. Then you'll need to computer tweaked.
Old Mar 28, 2005 | 05:55 PM
ot180's Avatar
ot180
sounds like a good project. thanks for the advice. Maybe i need to save up a bit more.
Old Mar 28, 2005 | 06:05 PM
STL94LT1's Avatar
STL94LT1
Heads/Cam.
Old Mar 28, 2005 | 06:06 PM
ElisTwoCents's Avatar
ElisTwoCents
St. Jude Donor '05 thru '24
Originally Posted by ot180
Hi,
thanks
Welcome to the Forum
Heads+Cam and headers
Old Mar 28, 2005 | 07:10 PM
NitrousSam's Avatar
NitrousSam
Long tube headers and a set of free flowing mufflers like Flowmaster, Borla, Magnaflow...port the heads and port match the intake, have the heads flowed and then match the camshaft to the flow numbers and swap the valve springs to match the new cam profile, consider roller rockers, get a new tune on your computer, consider an effective cold air kit. These items alone should get you where you want to be. You might consider a thinner headgasket for a slight compression enhancement but the gain will be pretty small.
You could save some money by purchasing the headers, mufflers, cold air kit used, you could also buy roller rockers used but I would want to see them and check them out before you do to make sure they are still smooth operating. If you find someone who is taking off a set of heads and they are upgrading to something larger you might get a smokin deal on a used set of factory ported heads that would bolt right on...and if the person you are buying them from is going with bigger heads you could potentially buy the matched camshaft and save even more money. The opportunities for getting 75 to 100 horsepower grow dramatically when you consider buying used stuff.
If you want to be successful at getting decent buys on good used stuff make it "VERY WELL KNOWN" what you are looking for and you have the cash ready to buy and I think you will be shocked at the number of people who will try to help you.
Happy Hot Rodding!
Old Mar 28, 2005 | 07:41 PM
cprgmr's Avatar
cprgmr
My heads and cam ended up being about 5k (although I did a bunch of other stuff at the same time).
I know your post states "without nos", but by far, N20 is the cheapest bang for the buck (if you don't mind re-filling bottles).
It can be a safe and reliable power adder without going into the engine.
Old Mar 28, 2005 | 07:44 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
Welcome to the addiction!!! with the above... the most conventional way to add that kind of power is thru heads\cam\intake\exhaust... but don't overlook forced induction. A good supercharger and a good tune can add up to those numbers
Old Mar 28, 2005 | 07:47 PM
FELNGR8's Avatar
FELNGR8
I got my heads and cam done and some small things on a 5000 budget. Then I did LT headers and custom exhaust for another 1800. That will give you 100 hp, but even wrenching yourself you'll have a hard time doing it for 3 grand.
Old Mar 28, 2005 | 07:53 PM
JackDidley's Avatar
JackDidley
A set of 4.10 gears will make it feel like you gained 100 HP. Less $$, no tuning issues.
Old Mar 28, 2005 | 08:46 PM
Caboboy's Avatar
Caboboy
What size headers should he look at?
Old Mar 28, 2005 | 09:22 PM
JackDidley's Avatar
JackDidley
Good ???
Old Mar 28, 2005 | 09:56 PM
raptornails's Avatar
raptornails
If someone was to have a good shop do a head/cam swap on an LT1, what can be the expected number of hours charged for labor?
Old Mar 28, 2005 | 11:35 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
heads/cam/headers and a tune will do it
Old Mar 29, 2005 | 04:19 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I would just juice it and pick your power.
Old Mar 29, 2005 | 08:38 AM
Red Tornado's Avatar
Red Tornado
Since he's planning to be around 400chp, I would opt for 1 3/4" tubes
Old Mar 29, 2005 | 09:24 AM
kwik_ta's Avatar
kwik_ta
God please lets not start this one again
To 100 hp
Old Mar 29, 2005 | 01:41 PM
DINO's Avatar
DINO
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I went to Cruise-In V with Vetteweiser
I think you are going to need a bit more than 3 grand ..
Old Mar 29, 2005 | 02:02 PM
Red Tornado
$5k is more like it.......to account for all the "better do this, then that, while i'm at it".
general rule of thumb is always double the initial estimate. this usually puts lumps in many throats
Old Mar 29, 2005 | 05:31 PM
F1Fan's Avatar
F1Fan
Cam, headers, and a tuner program
