LT4 hot cam install
Old Mar 28, 2005 | 06:23 PM
redvette6spd's Avatar
redvette6spd
Default LT4 hot cam install
What do you all think about what my machanic wants to do and charge me for my cam install. Ok this is my car it's lt4 with 39000 easy miles on the clock. I want a LT4 Hot Cam installed. He sed he would install but only waranty the cam and the work if he put on a new timing chan cam barings and springs and retaners. The price for just the cam install, and cam is $1500 no warnty. The price for the barings, cam, timing chan, retainers and springs is $2250 with warnty. I am not going to race this car just a little spirited driving seat of the pants fun. Do I need all this other stuff. Is it worth the gamble with the no warnty. Opinions please. Thanks
Old Mar 28, 2005 | 06:30 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Find another mechanic.
When you do a hot cam, it is vital to do the timing chain, springs, and retainers (IMHO). However, there is no need to change the cam bearings. Hot cam + a good set of springs + new timing set shouldnt be more than $600 or so.
I did a cam a tad bit more extreme than the hot cam, a billet double roller timing set, 1.6RR, new springs, retainers, etc, and upgraded to a new opti, and a mez water pump, and the total ended up being roughly $1100 (if I am remembering correctly)
Old Mar 28, 2005 | 07:21 PM
Hotred94's Avatar
Hotred94
No reason to change cam bearings unless they are damaged. I got cam, springs, 1.6 rr, and had them installed by a mechanic (I helped ) for about $1100.
Old Mar 28, 2005 | 07:30 PM
cprgmr's Avatar
cprgmr
I would suggest purchasing a Helms service manual (two volume set), read what's involved with the cam swap, pick up your gaskets and any tools you might not have, and tackle the job yourself.
You'll save a ton of money and you'll know that the job is done right.
Of course this assumes that you have a reasonable amount of mechanical ability.
It's not hard, just time consuming and the best part of it is really getting to know your car!
Old Mar 28, 2005 | 07:41 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
or at best get a second price quote. The price you were shot seems awful steep especially with no guarantee for the work done. Just because you own a vette doesn't mean you are made of $$$... and if you are it still does not warrant or justify such a ridiculous price.
Old Mar 28, 2005 | 07:51 PM
redvette6spd
cprgmr I am not into working on cars I would rather do a little overtime at my regular job to pay for the goodies. For what ill have in this car with a hot cam, headers and corsas I could have had your car DAMIT
Old Mar 28, 2005 | 09:40 PM
redvette6spd
How many hours labor for a pro to do the cam, timing chan, springs and retainers. Or dose aney one know what the labor book says for hours. Thanks
Old Mar 28, 2005 | 09:58 PM
Strick's Avatar
Strick
Drop by a Chevy dealer and see what the job would cost. There are dealerships with good mechanics, you just have to find them. They will offer you a flat rate price, it's on their computer. Labor is what's going to be the major cost.
Old Mar 29, 2005 | 08:36 AM
RED LT4's Avatar
RED LT4
I have a LT4 as well and did the hot cam install myself. It is not that hard just like everyone said its time consuming,. Try it, you will have alot of help here as well
Old Mar 29, 2005 | 11:11 AM
C4Crazy787's Avatar
C4Crazy787
Seeing as you already have an LT4 you only need the Cam, at 39K easy "maybe" a new timing set.
Old Mar 29, 2005 | 11:45 AM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
I dont see why you wouldn't replace the timing set while you are in there. The stock timing sets are junk- I have seen heftier bicycle chains. That chain breaks, and it is time to get a new engine. It is cheap insurance! You have to take the chain off, so why not replace it?
Also, the hot cam likes higher rpms. I would not feel comofortable at all going to higher rpms with a stock/40k mile timing chain. Just my 2 cents.
Old Mar 29, 2005 | 12:09 PM
purplemajesty's Avatar
purplemajesty
Wow! Does this price include the vaseline?
Old Mar 29, 2005 | 02:51 PM
C4Crazy787's Avatar
C4Crazy787
Originally Posted by MarkLT1
The stock timing sets are junk- I have seen heftier bicycle chains. Just my 2 cents.
Mark,
It's my understanding the LT4 already has the Heavy Duty timing chain, is this not correct??
If the HD set does have an "easy 39K" and *if* it checks out after a through inspection, why not reuse it.
Old Mar 29, 2005 | 02:59 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Mark,
Nope. The LT4 has a chain that is a little beefier than the LT1, but it isnt the "extreme duty" timing set.
see: http://www.gmgoodwrench.com/perfpart...397&section=ep
PN 12555887 is the stock LT4 chain, and PN 12370835 is the "extreme duty" setup, which is a beefier timing set.
Old Mar 29, 2005 | 03:09 PM
C4Crazy787's Avatar
C4Crazy787
Thanks, "extreme duty" set 210$ remember when a good dbl roller set was 40$
Old Mar 29, 2005 | 03:16 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
well.. it is the GM tax.
I got a billet double roller set for my LT1 for about $60 if I remember correctly. Problem is, you then have to drop the mechanical pump, and run an electrical water pump (not that that is too much of a problem.. just make sure you wire it well.. ask me how I know.. )
Old Mar 29, 2005 | 03:27 PM
boulderlt4's Avatar
boulderlt4
I just did a cam swap to a more aggressive cam than the hot cam.
I was told by two different shops that the LT4 timing chain would be plenty.
I don't think you need the chain. The LT4 may not be the beefiest, but it is fine!
To LT4 hot cam install
Old Mar 29, 2005 | 06:29 PM
cprgmr's Avatar
cprgmr
No problemo! It all boils down to how comfortable you are with this stuff. It can get expensive once you factor in all the tools you'll need, but hey, at least you get to keep the tools!
Now you know why I jumped on the LT4 - it was too good to pass up! I would've had to dump about $25k into the '93 to get it to where the '96 is currently at.
Old Mar 29, 2005 | 10:51 PM
redvette6spd
Well im going to give Doug Rippie a call for a quote also I don't expect mutch difference in price.The guy who gave me the first quote sed if I would have called a month or two ago price would have ben a little better. I have a 3 week wait to get the car in now. 95% of the work this shop dose is vetts and it is the season. Damn this fricken horse power is worse than dope.
Old Mar 30, 2005 | 12:46 AM
boulderlt4's Avatar
boulderlt4
GIVE ME MY MONEY BACK UNCLE SAM!
My shop is busy as hell right now also!
