Need help with wiring diagram analysis...
Recent repairs that were necessary new cap, rotor, distributor drive gear. I have an MSD box but it is out of the loop until I figure this out.
Unnecessary, new distributor that came with module, capacitor and pick-up.
As far as I can see there are 3 paths to ground for the coil primary control circuit. I feel the problem lies here because of the way the tach reacts in conjuction with the miss.
We have the noise capacitor (new), the tach circuit, and the circuit controlled by "electronic switch B" (new). The EST output and the Distributor Reference output from the ECM both hang at 1.4V at idle and climb steadily with RPM. They do not drop out or spike when the problem occurs. Am I missing something in the operation of the circuit here?
I will test out the tach circuit next, not sure how that could effect things other than having an intermittent short, perhaps something in the filter. I don't know how the filter works, what the signal going in is supposed to look like, or coming out. I will also double check grounds for the ECM.
How does the tach signal work? If I put a DVOM in the circuit, what should I see?
I'm trying to get as many ideas as possible. My time to work on the car is limited so I need some help brainstorming, then I can come up with a plan of attack.
Sorry so long, just trying to give a clear picture.... of mud
You know, maybe I am reading too much into this. I will go back to basics and try out the things you mention here. I've been caught up in what the tach is doing.
