Fuel pressure regulator question.
Old Mar 28, 2005 | 08:28 PM
DarthD's Avatar
DarthD
Default Fuel pressure regulator question.
I installed an adjustable fuel pressure regulator. When monitoring the fuel pressure with the vacuum line connected, what should happen to the fuel pressure when I rev the engine? Mine drops about 10psi. I thought the pressure should increase with more throttle. I may not have the vacuum line in the correct place.
85 Corvette
Old Mar 28, 2005 | 09:22 PM
CFI-EFI's Avatar
CFI-EFI
Possibly your pump, sock, or fuel filter aren't up to the task. Compare the fuel pressure with the engine idling, first with the vacuum hose connected and then with it disconnected. Disconnected, the pressure should be about 10 pounds higher. If it is, the problem isn't likely with the regulator.
RACE ON!!!
Old Mar 29, 2005 | 12:44 AM
vettenut85's Avatar
vettenut85
RACE ON!!!
cfi is right on.when you rev the engine the vacumn drops and the fuel pressure should rise.
Old Mar 29, 2005 | 08:29 AM
Swirk's Avatar
Swirk
I run my AFPR without the vacuum line attached.
Old Mar 29, 2005 | 11:56 AM
MrNuke's Avatar
MrNuke
Which kind of defeats the purpose. Basically you are running at a constant full/highest PSI to your injectors..
On a stock FPR it adds a few PSI fuel, little performance mod, but with an AFPR it's not needed.
Old Mar 29, 2005 | 04:00 PM
Swirk's Avatar
Swirk
I run it that way due to the supercharger. I never want it to go below 43 psi, so that is the lowest fuel pressure it will run. I should have stated that in the first post.
Old Mar 29, 2005 | 04:58 PM
DarthD's Avatar
DarthD
At idle, the pressure increases 4psi when I remove the vacuum line.
Old Mar 29, 2005 | 06:30 PM
CFI-EFI's Avatar
CFI-EFI
That doesn't seem like much, but at least it's going in the right direction. Is the engine pulling good vacuum? Any vacuum leaks? The pressure SHOULD increase, when the vacuum drops, as yours does when you disconnect the vacuum at idle. Other than observing the pressure dropping when you rev it, are you experiencing any problems? Possibly the fuel pressure drop you noticed, was after the throttle was closed and the vacuum increased.
RACE ON!!!
To Fuel pressure regulator question.
