Rear wheel bearing question
Old Mar 28, 2005 | 08:30 PM
BillSF49's Avatar
BillSF49
Default Rear wheel bearing question
How much play is acceptable when checking rear wheel bearings? When checking, I place my hands at 12 oclock and 6 oclock on the rear tire, when jacked up and push/pull back and forth. Both rear wheels have a little play, but it is minimal. Should there be a little play? or should it be tight and not move at all? I have 92k and am wondering if it is time for a wheel bearing change.
Old Mar 28, 2005 | 08:50 PM
CF6873's Avatar
CF6873
I posted this same question a few months ago and was told there should be no play. I replaced mine with new Timkens and now there is no play.
Old Mar 28, 2005 | 09:19 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
There should be no play
Old Mar 28, 2005 | 09:38 PM
Frizlefrak's Avatar
Frizlefrak
No play is correct....but make sure you don't have a bad bushing that's causing the play. Would not be good to spend $300 for new bearings and find out that $50 worth of bushings would have solved the problem.
With 12 and 6 play, check the strut rod bushings. With 9 and 3 play, check the rear control arm (trailing arm) bushings.
Your issue may very well be wheel bearings, but rule out the cheap and easy stuff first.
Old Mar 28, 2005 | 11:50 PM
BillSF49's Avatar
BillSF49
Thanks for all the tips. I bought all poly bushings for the control arm, dog bones, and strut rod about a month ago, so I will go ahead and start the project, will go ahead and change the bearings since I am down there. Appreciate all the help.
Old Mar 29, 2005 | 04:08 PM
CAJUN C4's Avatar
CAJUN C4
New ones will have slight play.I believe the radial runout limit is
.060" - 080" or something I'd have to check my Shop Manual.My new ones had very slight play.
Old Mar 29, 2005 | 11:54 PM
froggy47's Avatar
froggy47
None
To Rear wheel bearing question
