front swaybar bushing brackets
Old Mar 29, 2005 | 01:29 PM
johnno!'s Avatar
johnno!
Default front swaybar bushing brackets
Happy Spring everyone! I am getting into the spirit and getting ready to install 30mm and 26 mm swaybars on my 95. I just got the new poly bushings in today, but on the D bushings, the metal brackets that you bolt the bushing to the frame with were not included. Are these interchangeable for all sizes, or do I have to order them sepretly? I got energy suspension P/N 3-5142G from suspension.com. if anyone has any experiance with this I'd appreciate any help before I tear into it.
John
Old Mar 29, 2005 | 02:19 PM
dynalead's Avatar
dynalead
Interchangeable.
Old Mar 29, 2005 | 08:21 PM
johnno!'s Avatar
johnno!
so theorectically, you could upgrade swaybar sizes and just bore out the stock bushings?
Old Mar 29, 2005 | 08:47 PM
MaxLean's Avatar
MaxLean
Yup. I'm sure it's cheaper for GM to have one part number for the brackets, and multiple part numbers for the rubber.
Old Mar 30, 2005 | 12:21 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Yes. You should just buy the bushings you need. Check for part numbers at www.suspension.com
Old Mar 30, 2005 | 09:32 AM
MYCoupe's Avatar
MYCoupe
You should have no problems with the stock brackets. I just finished putting in my 30mm sway bar as well (stock was 26mm) and reused the stock brackets.
Old Mar 30, 2005 | 09:37 AM
edsalinas's Avatar
edsalinas
St. Jude Contributor
John
New brackets should've came with them???
Old Mar 30, 2005 | 11:11 AM
johnno!'s Avatar
johnno!
thanks guys, thats exactly what I wanted to hear. I am a little disappointed that for the price of the kit it didnt include brackets, but as long as I know Im all set, I'll get over it real quick.
Old Mar 30, 2005 | 01:07 PM
Corf's Avatar
Corf
John
Bought the same front kit 3.5142G from suspension.com yesterday and the rear kit 3.5151G as well. Both kits come with end link set but only the rear is available with brackets.
Old Mar 30, 2005 | 04:19 PM
johnno!'s Avatar
johnno!
thats exactly what I got, sounds like all is well
Old Mar 30, 2005 | 05:26 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I've done the upgrade and used the old ones, no problem
To front swaybar bushing brackets
