Em Header Clearance
Old Mar 29, 2005 | 06:39 PM
Donne Trav's Avatar
Donne Trav
Default Em Header Clearance
Has any one had any problems with HEADER CLEARANCE, specifically EM's,
TPIS, etc.? I've seen some pixs on the forum that suggest a few of these
headers might occasionally scrape the ground on the sometimes
"bumpy ride" at various speeds. Thanks.
Old Mar 29, 2005 | 06:44 PM
cprgmr's Avatar
cprgmr
None at all with the EM's on my LT1. The only thing you have to do for clearance is reverse the drivers side motor mount bolt.
Old Mar 29, 2005 | 06:57 PM
crheinish's Avatar
crheinish
I run Hooker's, no clearance problems. Car is not lowered.
Donne Trav's Avatar
Donne Trav
Default Re: Header Clearance
What's up with the "reversing of the drivers side motor mount"? Anyone
have any pixs? I don't have a clue! I haven't heard this mentioned at all
in the past on the forum. THANKS.
Old Mar 29, 2005 | 07:23 PM
cprgmr's Avatar
cprgmr
Not specifically the motor mount, but the bolt that runs through it and attaches it to the frame. All you have to do is remove the bolt and nut, reverse the bolt direction and put the nut back on (torquing to proper specs of course).
It's a piece of cake and well worth it to run these headers.
Old Mar 29, 2005 | 10:03 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
what is it with multiple posts across the C4 section??? Just so you can cover all the sections... you forgot to post this in the parts section.
To Em Header Clearance
