My car, for the third time has mysteriously lost its idle. It comes and leaves without warning. Cracking open the throttle with a spacer allows it to idle. Cleaning the throttle body/ IAC passages did nothing at all. I know it shouldn't be connected, but code 74 for the dimmer circuit sets when it goes astray.
That method will set the TPS but you still need to set base idle to 450rpm with the IAC pintel fully extended.
Vacuum leaks can be intermittent, depending on source. You may be able to catch it with a vacuum gauge on a manifold port. Of course manifold vacuum will fluctuate with entine idle speed too.
