Let it Bleed!!!
Old Mar 29, 2005 | 08:53 PM
jrscott's Avatar
jrscott
Default Let it Bleed!!!
I was told, just today, that there is such thing as gravity brake bleeding. What it entails is simply attaching a piece of tubing to the bleeder nipple and running the tubing into a clear container. Partially open the nipple and it will bleed simply through gravity. Time is the issue. Has anyone ever heard of this or tried it?
Old Mar 29, 2005 | 09:01 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
What I did was to imerse the end of a piece of tubing into a container of old brake fluid. This prevented air from being pulled back when I released the brake pedal.
I don't know how long the gravity method would take nor if fluid would leak past the MC piston into the lines to replace fluid that leaked out the bleeders.
Old Mar 29, 2005 | 09:31 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I've used this method on all types of vehicles, whether replacing lines, cylinders, calipers or all of the above. I'll bolt everything together and leave all the connections loose for a while, eventually tightening everything progressively outward toward the wheels. Obviously, don't let the master cylinder run dry. When time for the final bleeding, very little bleeding will be needed. This procedure has always served me well.
Old Mar 29, 2005 | 09:38 PM
JCAIRE2's Avatar
JCAIRE2
I don't think you can gravity bleed an ABS system. Used to bleed my old manual brakes on my pickup with a gravity bleed. Just get a buddy (or the wife) to help you bleed the brakes properly.
Old Mar 29, 2005 | 10:17 PM
mesteffen's Avatar
mesteffen
Last fall when I did my brake job I gravity bled. I just opened the bleeders with a plastic hose on them and let the fluid flow. You have to remember to not let the master cylinder empty, but it worked fine for me.
To Let it Bleed!!!
