[LT1] How remove throttle linkage from throttle body?
Old Mar 30, 2005 | 10:25 AM
Lone Ranger's Avatar
Lone Ranger
Default [LT1] How remove throttle linkage from throttle body?
In order to get the throttle body completely off, you have to remove the throttle cable linkage assembly. How do you accomplish this?
Want to disassemble the throttle body and clean it. I bought the gasket kit.
Old Mar 30, 2005 | 10:42 AM
johnno!'s Avatar
johnno!
I just did it yesterday, theres a small slit that the wire liines up with and can be pulled out through, the little peg comes out through a small hole at the end of the slit. you cant just tug on it, you gotta finesse it to get the peg to line up with the hole.
Old Mar 30, 2005 | 10:44 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
With your hand move the TB to WOT then push the little cable wire up and you will see the little pin and slit which you can easily remove it from.
Old Mar 30, 2005 | 12:25 PM
Lone Ranger
Okay, cool. Thx guys
To [LT1] How remove throttle linkage from throttle body?
